Adding GFCI But Leaving Existing Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:12 PM   #1
Adding GFCI but leaving existing circuit
Please see the attached sketch before looking at my explanation.
Basically I want to remove a receptacle and replace it with a GFCI on a new dedicated circuit.
The problem is the power to the existing receptacle also feeds a light in my bathroom. If I replace the existing box with a larger 4"x4"x2" box, is it OK by code, to 1.) use that box as a junction box to reconnect the existing circuit(power to light) and 2.) connect the GFCI on the new dedicated circuit?
Strugglin is offline   Reply With Quote
Old 10-26-2011, 01:15 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Yes, and it dosen't have to be a 4X4 box.
If you can use plastic, a 23 cu inch box will be enough.
jbfan is online now   Reply With Quote
adding a new circuit breaker panel Lana65 Electrical 0 09-23-2010 05:39 PM
Code question on extending existing 120v circuit radiercks Electrical 15 11-14-2009 06:29 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 06:14 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
