-   -   Adding GFCI but leaving existing circuit (http://www.diychatroom.com/f18/adding-gfci-but-leaving-existing-circuit-121380/)
Strugglin 10-26-2011 01:12 PM
1 Attachment(s)
Please see the attached sketch before looking at my explanation.
Basically I want to remove a receptacle and replace it with a GFCI on a new dedicated circuit.
The problem is the power to the existing receptacle also feeds a light in my bathroom. If I replace the existing box with a larger 4"x4"x2" box, is it OK by code, to 1.) use that box as a junction box to reconnect the existing circuit(power to light) and 2.) connect the GFCI on the new dedicated circuit?
jbfan 10-26-2011 01:15 PM
Yes, and it dosen't have to be a 4X4 box.
If you can use plastic, a 23 cu inch box will be enough.
