Adding GFCI Breaker To Ground Outlets?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:51 PM   #1
Question
Adding GFCI Breaker to Ground Outlets??
Hey Everyone,
I have a house with full rooms of two prong outlets that exist on the same breakers. I was told by a local home improvement teacher that if I replace the breaker with a GFCI breaker of the same size I can safely put in three prong outlets. Want to check and see if they were telling me the truth?
Thanks.
joerunner2 is offline   Reply With Quote
Old 11-10-2011, 09:17 PM   #2
Rewards Points: 6,652
Do a search on here. This is a subject that has been beaten to death, more than the proverbial dead horse.
Old 11-10-2011, 10:17 PM   #3
Question
Re: Did a search and can't find anything but GFCI outlets, not GFCI breakers.
I didn't find anything on whether it is safe to replace a regular breaker with GFCI breaker and then switch outlets to three prong. All I get is trading out two prong for GFCI outlets. If you would be so kind to answer this question again in this post it would be appreicated. Thank You.
Old 11-10-2011, 10:36 PM   #4
First thing is, what panel do you have, and what is the age of the wiring that is in the structure already? Also, is it BX, Knob & Tube, Romex, Aluminum wiring? The only way to give you a proper answer on the breaker swap, is more info. In theory, the breaker would work the same as the outlet, but not as good, as if there was a ground in the circuit.
Old 11-10-2011, 11:23 PM   #5
liscenced electrician
Rewards Points: 538
you can legally put a 3 prong receptacle on circuit with no ground if it is gfci protected and you label the receptacles "no equipment ground." This isnt as safe as having a ground, but it is a legal, code compliant installation
jimmy21 is offline   Reply With Quote
Old 11-10-2011, 11:38 PM   #6
Right! They need to be labeled "no equipment ground".
Billy_Bob is offline   Reply With Quote
Old 11-11-2011, 12:22 AM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,942
It's an identical solution. You will probably find that it's cheaper and easier to just replace the first receptacle on each circuit with a GFCI instead of using GFCI breakers, though.
mpoulton is offline   Reply With Quote
Old 11-11-2011, 02:23 AM   #8
Rewards Points: 538
If you know where the first receptacle is. Older homes it may hit a light switch then 3 junction boxes then branch out to receptacles from there
Old 11-12-2011, 06:32 AM   #9
Rewards Points: 160
Are you sure your boxes aren't grounded? Many times the ground wire was terminated at the box somewhere since it wasn't used when the wiring was installed. Get a tester and see if the box itself is grounded, and you can just install a jumper cable from the outlet to the box.
matt151617 is offline   Reply With Quote
Old 11-12-2011, 12:16 PM   #10
Licensed electrician
Rewards Points: 1,634
Using a GFI breaker or receptacle does not add a ground to a receptacle. It only allows 3 hole receptacles to be installed on ungrounded circuits.
jimmy21 (11-12-2011)
Adding ground wires michaelcherr Electrical 2 02-16-2011 08:16 AM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 08:48 PM
