Old 01-18-2013, 11:42 PM   #1
adding a garage junction box
I need to add an 'old work' junction box to my garage (behind a firewall). Does the box have to be metal, or will plastic be sufficient (pass a code inspection)?
tlynch833 is offline   Reply With Quote
Old 01-18-2013, 11:46 PM   #2
Need to be asking your local building dept. not some strangers that have no idea where your located since you did not add you location in your profile.
Old 01-18-2013, 11:49 PM   #3
it has to be rated for outdoor use...remember to run the wires in a conduit.
BNTHERE is offline   Reply With Quote
Old 01-18-2013, 11:52 PM   #4
Licensed Electrician
k_buz's Avatar
1) Why?
2) Why?
Location...Location...Location
Old 01-18-2013, 11:55 PM   #5
the romex is run along the ceiling. My understanding is that conduit is not required unless exposed wire is below 7" from the ceiling. Does that sound right to you?
Old 01-18-2013, 11:58 PM   #6
k_buz's Avatar
If the romex is surface mounted, why wouldn't you simply install a surface mounted box?
Old 01-19-2013, 12:11 AM   #7
Whether its surface mounted or in the wall, is there a requirement on being a metal box? I was hoping to put the box in the wall and putting a putting some shelves over that part of the wall.
Old 01-19-2013, 12:15 AM   #8
k_buz's Avatar
You can use plastic unless there are local codes stating otherwise. If I'm not mistaken, a 1G plastic box has a 1 HR fire rating.
The Following User Says Thank You to k_buz For This Useful Post:
tlynch833 (01-19-2013)
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Adding Circuits to attached garage john8791 Electrical 1 02-10-2011 02:55 AM
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 01:30 PM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 08:33 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 05:44 AM
