Adding Fixtures To An Existing 3way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 08:37 PM   #1
Adding fixtures to an existing 3way switch
I need to add 2 fixtures to an existing circuit that has the following set up:
Power in 14/2 - 1st fixture - 14/3 - 2nd fixture - 14/2 - 3way switch - 14/3 - 4way switch - 14/3 - 3way switch.
mom5va is offline   Reply With Quote
Old 08-14-2012, 08:58 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You will need to wire the new fixtures to the existing light fixtures. You will not be able to feed the new lights from any of the switches.
The Following User Says Thank You to k_buz For This Useful Post:
mom5va (08-15-2012)
Old 08-14-2012, 09:02 PM   #3
DIY staff
Rewards Points: 7,174
Exactly what is the question?---the lights are after the switch set up---so all lights --existing or new will come from the power that exits the last switch.and use the same neutral.
Old 08-15-2012, 12:39 AM   #4
" Euro " electrician
frenchelectrican's Avatar
The best location to tie in new luminaires is either exsting luminaires only due the wiring conferation set up so it much easier to just hook up to the luminaries.
But S.V.P.( Please ) pay attetion to the connections on the luminaires at either luminaire location this is crictial so you will not mess up the connections for the rest of the circuit.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
mom5va (08-15-2012)
Old 08-15-2012, 07:54 AM   #5
Thank you all. Sorry I did not give location. I'm very new at this. I am in Virginia. So with the power coming into the first fixture I need to run wire from the new fixtures back to the first fixture.
Do I just use 14/2, join the 2 new fixtures then run the wire to the 1st fixture and join them all neutrals together and the new black to the existing black/red
Old 08-17-2012, 08:52 PM   #6
Smile
I just wanted to say Thank you to all of the DIYers and the Pros that take time out of thier day to answer questions from people like me. You will never really know how much you have blessed so many people, especially me. I have learned so much. I solved my wiring problem. It was much easier to rewire the switch set up to sw1-sw2-sw3-Lt1-Lt2-Lt3-Lt4. Should be able to call for electrical inspection on Monday. Then on to plumbing!
Old 08-17-2012, 09:10 PM   #7
DIY staff
Thanks---We have a bunch of good folks here--more than a few have plumbed a house,too.
Adding to a plastic switch box jdjd Electrical 2 06-25-2012 03:35 PM
replacing an existing 1-way decora light switch with a dimmer switch maljeff Electrical 3 01-11-2012 12:49 PM
Add 2 ceramic fixtures to existing switch diyneedshelp007 Electrical 4 03-01-2010 02:28 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
