Adding External Wall Sconces To Attached Unfinished Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 02:35 PM   #1
Adding external wall sconces to attached unfinished garage
Hi there,
I'm planning on adding two external wall sconces (lights), one on either side of the garage door in my unfinished attached garage, to light up the driveway at night. There are existing security lights not too far from where the sconces will go (facing different directions), so it shouldn't be particularly difficult to run new wire from these lights to the new sconces.
However...
I spoke with an electrician about doing this job, and he indicated that I would need to cover up some of the wiring with drywall - there's some wiring for switches and outlets that the previous owner had installed, the basic pattern is that the wire runs down from the top plate of the wall and along the inside of a stud into an outlet box, and this wire needs to be covered up. I had never heard of this requirement, and it could very well be a local requirement. I can understand if, say, I'm running wire perpendicular to and through studs, but I'm uncertain if this applies in my situation.
Would anyone happen to know if this is truly the case, or since the garage is unfinished, can I just keep the wires exposed (provided they're routed and fastened properly for an unfinished garage space)?
Also, any general tips and best practices for how to properly run wire in an unfinished garage?
Thanks in advance for any advice!
FremontJoe is offline   Reply With Quote
Old 03-07-2012, 02:37 PM   #2
Julius793's Avatar
Originally Posted by FremontJoe
Hi there,
However...
We just had 2 threads about garage wiring take a look.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-07-2012, 02:53 PM   #3
joed's Avatar
Rewards Points: 12,392
The requirement is to protect the cable from damage. Drywall is one way since the cable will no longer be exposed to damage. There are other ways including sleeving it in conduit for protection.
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Sub Panel to Attached Garage marly Electrical 4 06-02-2011 12:34 AM
Adding an attached shed to back of garage wall Augy Building & Construction 12 03-28-2011 07:01 PM
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 09:23 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
