Adding Exhaust Fan To Existing Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 09:20 AM   #1
Question
Adding exhaust fan to existing light circuit
I have a switch box with two cables (14/2) which controls two recessed lights. I want to add exhaust fan to same switch so existing lights and new fan will come on together. I ran a new wire to from switch box to fan location. The wires are not connected. Do i need to determine supply and load at switch box or just connect all the colors together? thx
EelectricP is offline   Reply With Quote
Old 08-19-2011, 09:31 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Yes you have to determine which is supply and which is load if you want to have the load switch controlled. Connect all the colors together and the fan/light will be on all the time.
Kyle
Plan on turning an existing light circuit into 3way? mj876 Electrical 8 08-30-2010 05:55 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 01:46 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
