Adding A Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 08:20 AM   #1
Adding a exhaust fan
I'm adding a exhaust fan to my master bedroom and I'm a little confused about the wiring. I plan on adding a duel switch to the current single switch that controls the vanity light. The top switch will control the vanity light, the bottom switch will control the exhaust fan.
My question is, can I just pig tail off the current wiring in the vanity switch box? What would you recommend?
Oswald is offline   Reply With Quote
Old 03-27-2009, 09:13 AM   #2
This is how I would do it, but I'm no expert. Don't know why you are bringing the GFI outlet into the equation.
EDIT: updated image to reflect theatretch85's suggestions
surrogate is offline   Reply With Quote
Old 03-27-2009, 09:23 AM   #3
Nice diagram. For the GFI I was just showing that it was existing and being fed from the switch.
I'm just worried about pig tailing to much. As you can see from my diagram there are already quite a few wires in the mix.
Old 03-27-2009, 10:06 AM   #4
I updated the diagram to include the gcfi. Feed the switch from the gcfi instead of the other way around.
Old 03-27-2009, 07:15 PM   #5
Rewards Points: 508
Send a message via AIM to theatretch85
Bathroom lights and fans are NOT required by code to be GFCI protected unless specifically indicated as such by the manufacturer. Running power into both the switches and the GFCI outlet is just fine, you do not need to run them through the GFCI. Think about what happens in the event you do trip the GFCI; you'll be left in the dark in the bathroom with no lights.
Personally I would not put the lights and fan on the GFCI outlet.
theatretch85 is offline   Reply With Quote
Old 03-27-2009, 08:03 PM   #6
From the ex fan cable, put the white with the whites under the wire nut.
Your stacked switch wil have one terminal for the power (existing pigtai; to light switch) and two separate terminals for the light and fan blacks.
220/221 is offline   Reply With Quote
Old 03-29-2009, 07:40 AM   #7
Worked great. I attached the neutral to the existing wires (under the wire nut), put the red wire on the black screw, and put the blacks from the light and fan on the brass.
Thanks for the help.
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Central-vac exhaust curls00 General DIY Discussions 4 03-09-2008 12:28 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
