Adding An Electrical Water Heater. Only Single Pole Available In Box. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2013, 02:31 PM   #16
Oso954's Avatar
Rewards Points: 1,106
So occasionally, we would like the ability to drain that 80 gallon in 10 minutes.
Do you realize that the recovery time after such draining will be 2.5 hours or more ?
Oso954 is online now   Reply With Quote
Old 08-23-2013, 03:35 PM   #17
dmclean701's Avatar
Rewards Points: 152
Remember the breakers are there just to protect the wiring from getting too hot. A 200 amp main panel might have 300 amps of breakers in it but the loads on each are much less, some not on when others are etc, so the total is usually less than 200 amps, or the main breaker would be tripping all the time.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 08-23-2013, 04:18 PM   #18
Rewards Points: 590
But how can I ensure I won't be overloading that 90amp breaker?
I'm worried because in the master bedroom that runs off of that breaker, the lights dim for a 1/2 second when I turn the TV on.
noone is offline   Reply With Quote
Old 08-23-2013, 07:38 PM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
Time to get out a voltmeter and start making measurements....
And...if it's incandescent lighting...maybe consider going to LED or CFL
Old 08-24-2013, 11:20 AM   #20
Rewards Points: 590
Where do I measure volts at? At the panel? Hook the red up from the multimeter to the black wire out of the breaker and then ground the multimeter with the black wire to the ground in the panel?
Old 08-24-2013, 02:33 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
A voltmeter is not going to give any useful info on the actual load.
If those breakers are just feeding lights and receptacles, don't worry about the load taxing a 90 amp sub.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-26-2013, 11:26 PM   #22
dmclean701's Avatar
Rewards Points: 152
You can put a clamp on ammeter on the feed into the sub-panel and measure the actual draw when you turn everything on. Measure both legs (black and red) then you can see how close to 90 amps it is. Be careful reaching into the panel because it will have to be hot to do this.
Old 08-27-2013, 05:34 AM   #23
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
That sounds like more of a loose connection than an overload.
I would check for back stabbed devices since the MB is on a 15 amp circuit.
wirenut1110 is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
