Adding Electrical Outlet Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 02:55 AM   #1
I posted this in the woodworking forum and I got a ton of rants so please spare me that please. I'm not an idiot and I intend on completely turning off all power before attempting anything.
So I've been researching adding a couple of electrical outlets to my garage (where the panel is). I want to run a new 120v outlet for the tablesaw (older craftsman 113 series) so that it is on it's own circuit and a 240v outlet for a grizzly G1029z2 DC on it's own circuit as well.
What amp 120 circuit should I add for my tablesaw? Will a standard 15a breaker be fine?
What amp 240 circuit should I add for my DC? The motor plate states 12 amps and the manual says the electrical is a minimum circuit size of 20. Should I just install a 20amp circuit or go with larger circuit?
Need recommendations on the gauge of wire to use on each circuit.
adrianmcmanus79 is offline   Reply With Quote
Old 03-12-2012, 06:56 AM   #2
Rewards Points: 730
Does your home have a disconnect separate from the main panel? If not, you will not be able to "turn off all power" and you are inviting a trip to the burn unit.
Mark
busman is offline   Reply With Quote
Old 03-12-2012, 07:12 AM   #3
DIY staff
Rewards Points: 7,174
I suggest a 20 amp for the 120 line---12 guage wire--
The 240 line--I'll leave that for one of the licensed electricians--My shop 240 line is a 30 amp so I could run a saw or an arc welder from the same outlet.
Old 03-12-2012, 07:29 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
From the info given it sounds like two 20 amp circuits one wired for 120 and one for 240 should work for you. If the saw only has a three wire cord then 12-2 would work for both circuits.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-12-2012, 08:35 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Mark
Seems the warning is a little extreme. The danger of arc flash in a 240 volt residential panel is pretty low.
Coastal South Carolina
Old 03-12-2012, 09:55 AM   #6
Rewards Points: 730
Do you have a basis for that statement. As one who has survived a residential meter enclosure explosion, I can tell you that the danger is real. This misconception comes (in my opinion) from all the people who have started 120V arcs on circuits protected by circuit breakers. This is a lot different than the results you will get by bridging the mains in a hot 240V panel with a piece of #10 wire (or even worse, a steel tool). At that point, it is unlikely that your arc will trip the primary OCPD on the transformer and the arc will continue until the metal is gone.
The danger is real and people (friends of mine) have gone to the hospital for this mistake.
Mark
Old 03-12-2012, 11:14 AM   #7
Ravenworks's Avatar
Mark
It's real and it's scary when it happens ,I know someone that dropped a screw inside a panel and the outcome was a violent ball of fire.
Ravenworks is offline   Reply With Quote
Old 03-12-2012, 12:00 PM   #8
Mark
If I detect power at the panel after flipping the main switch I won't mess with it. My voltage detector light would be able to safely tell me if the panel was still hot right? Trust me I'm not trying to kill myself but it doesn't seem to be that difficult if I can safely turn the power off and I install the proper breaker, outlet, and wire right?
Old 03-12-2012, 12:57 PM   #9
jbfan's Avatar
Rewards Points: 234
Run a 12/2 w ground for the table saw, and a 12/3 w ground for the dust collector.
You will not use the white wire in the 12/3 but if things change and you needed a neutral it is there.
Turn the main breaker off, then check several places in your house for power.
Remember that the wires on top of the main breaker are still hot
Old 03-12-2012, 01:07 PM   #10
Rewards Points: 730
I know I sound like the voice of doom, and that's probably not appropriate. Obviously, the chances of a serious arc accident are fairly low in a residential panel, but without understanding what the risk factors are, it's not easy to know the level of danger. I have seen cases where the act of just removing the panel cover has caused a flash because internal parts were broken and the cover was holding things in place. The bottom line is that there is no guarantee that you will even get to the point of checking for voltage without an incident.
The point of my original post was that unless you have an outside disconnect, then the most dangerous part of your panel (the unfused line side lugs) will be energized even if you throw the main to off. I just want to you to be aware of the hazard that is not obvious to all that open their panels.
Mark
Old 03-12-2012, 01:19 PM   #11
Rewards Points: 150
Mark
It's a good reminder for us DIY'ers. Thanks.
silversport is offline   Reply With Quote
Old 03-12-2012, 01:28 PM   #12
Rewards Points: 2,516
True of any disconnect. Downstream from disconnect is shutoff but upstream is still ready to bite ya.
hammerlane is offline   Reply With Quote
Old 03-12-2012, 01:30 PM   #13
Mark
Thank you for the heads up, I know you come from a good place with your words of caution. Assuming I can shut the power off completely with the main switch, then the only real danger would be the 2 leads coming into the panel right?
Old 03-12-2012, 01:38 PM   #14
The conductors coming into the panel the lugs AND THE BUS BARS OF THE PANEL
Old 03-12-2012, 01:51 PM   #15
found a better photo the lugs and the bus bars. Lugs will still be hot with main breaker off but bus bars will not.
The Following User Says Thank You to hammerlane For This Useful Post:
adrianmcmanus79 (03-12-2012)
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Help - Adding a third outlet off of 1 outlet, shallow box so no pigtailing stlramscards Electrical 20 02-01-2011 08:52 PM
Adding an outlet tunaman Electrical 6 01-30-2011 02:10 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
