Adding An Electrical Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 02:59 PM   #16
Love for Construction
<*(((><'s Avatar
Originally Posted by danebhut View Post
Just like in the attached picture, yea?
Is there a danger or disadvantage to using 12/2 "just to be safe"? Or would that actually be unsafe for some reason?
Is there a way to know or determine 15 or 20 amps other than (I'm guessing) connection some kind of meter/gauge to the outlet I'm starting from? The outlet is just a standard one in the living room, if that helps.
You have turned the breaker off when working on this circuit correct? The breaker that you turned off to work on this will have the amperage stamped on the end of the switch or above it on the breaker.
If you look at the link that I put in my previous post, you will see the bottom receptacle mounting screw has a brass tab behind it. This connects with the screw that the ground wire attaches to and grounds the box via the receptacle mounting screw. Hope this makes sense. If your receptacle doesn't have this then you need to ground the box at the back with a green mounting screw attached to a ground pigtail.
-luke-
<*(((>< is offline   Reply With Quote
Old 12-13-2011, 03:37 PM   #17
Yes, I've had the breaker off, I'll check and go from there as far as 12 or 14 gauge wire.
I didn't see your link, but looking at it now that makes sense. I always thought those tabs were just to keep the mounting screw with the receptacle during installation and work, I didn't realize it acted as a conductor to help ground the box via the mounting screw from the self-grounding receptacle. Good to know!
danebhut is offline   Reply With Quote
Existing concrete slab has electrical and cat5 outlet. Would like smaller faceplates. noone Electrical 5 10-17-2011 02:29 PM
Adding outlet for above stove microwave bobbysan Electrical 6 04-28-2010 07:01 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
