Adding Doorbell Chime In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 08:33 AM   #1
adding doorbell chime in basement
I currently have a 10v chime for my doorbell which operates off a 10v/5va transformer. I want to add a chime in the basement. All the chimes I find are now 16v. If I change my transformer to a 16v/30va will I still be able to use my existing 10v chime with the new 16v transformer. If not, do they still make 10v chimes and transformers. I would reallly like to keep my current 10v chime if possible.
dagu200 is offline   Reply With Quote
Old 04-01-2011, 09:26 AM   #2
Electrical Contractor
kbsparky's Avatar
I have not been able to find any 10 Volt chimes any more. You can still buy the transformers, but the chime itself is another matter.
Even the cheapie "builder's model" comes with a 16 Volt unit these days.
-KB
Old 04-01-2011, 09:27 AM   #3
Rewards Points: 1,440
The 10 volt chime will probably work okay on 16 volts provided it is all mechanical (coils, bells, xylophone bar) as opposed to electronic (circuit boards, speaker). It is still possible its life will be shortened if guests hold the door button in for a long time.
AllanJ is online now   Reply With Quote
Old 04-01-2011, 09:32 AM   #4
the current 10v chime does have a circuit board and speakers. Is there any danger of 'burning' it out by trying it with the 16v?
Old 04-01-2011, 10:25 AM   #5
Assuming this is DC: You could use separate power supplies and a relay. Keep the existing system, connect the relay in parallel with the chime on the existing system and in place of a button on the new 16v system.
thadsaab is offline   Reply With Quote
Old 04-01-2011, 11:56 AM   #6
Great and grave danger of burning out the 10 volt electronics with 16 volts.
Never connect anything to higher voltage than it was meant for.
Old 04-01-2011, 01:00 PM   #7
Rewards Points: 320
The chimes and the transformers are cheap. I would just replace the existing chime with a 16 volt and replace the transformer with a 16 volt trans.
teamo is offline   Reply With Quote
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Adding new furnace vent in basement campbellp HVAC 0 12-11-2010 09:41 AM
Adding heat registers to basement brick1930 HVAC 0 08-24-2009 06:52 PM
Adding a basement Sliver Building & Construction 5 05-16-2009 11:38 AM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
