Adding A Dishwasher And Garbage Disposal - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 05:37 PM   #1
Rewards Points: 81
Adding a dishwasher and garbage disposal
We are updating our kitchen cabinets and in the process we will be adding a dishwasher and garbage disposal. Should I plan on having these two on their own separate circuit?
I have a circuit that is no longer in use that I could reroute or I have the circuit that powers most of the lights and outlets in the kitchen.
Total Tool is offline   Reply With Quote
Old 01-22-2012, 05:49 PM   #2
jproffer's Avatar
Rewards Points: 706
Many people run a multi-wire branch circuit for the DW and GD. Both sides to one receptacle...one side switched for the GD, one side always hot for the DW.
Also, I don't think lights can be on the same circuit as kitchen receptacles...but it depends on how major your renovation is, so it could be allowed to stay that way for now.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
Total Tool (01-22-2012)
Old 01-22-2012, 05:56 PM   #3
Rewards Points: 582
we would install -single circuits for each appliance....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-22-2012, 07:03 PM   #4
Julius793's Avatar
Many people will put them on the same, what size dishwasher?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
Old 01-22-2012, 07:07 PM   #5
DIY staff
Rewards Points: 7,174
In the county that I work the dishwasher must have its own 20 amp dedicated circuit.
Old 01-22-2012, 07:07 PM   #6
Rewards Points: 162
I'm remodeling my kitchen now and am putting both on a single 20A circuit. I've had the same configuration in my last kitchen for years and never tripped a breaker.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
The Following User Says Thank You to stubborn1 For This Useful Post:
Old 01-22-2012, 07:12 PM   #7
Julius793's Avatar
Originally Posted by oh'mike
In the count that I work
Do you mean county?
Old 01-22-2012, 07:15 PM   #8
Rewards Points: 582
good point mike .also in the instruction manual and install say it must have its own dediciated circuit..
Old 01-22-2012, 07:17 PM   #9
DIY staff
Thanks---I never could spell--and the spell check didn't recognize count as bad.
Old 01-22-2012, 07:18 PM   #10
" Euro " electrician
frenchelectrican's Avatar
Pit ???
Merci,
Marc
Old 01-22-2012, 07:20 PM   #11
DIY staff
It can be an electrical nightmare trying to update an older kitchen---a lot more circuits today than the old days,
Old 01-22-2012, 07:21 PM   #12
If the dishwasher installment instruction say delcaited circuit then it have to be it own circuit otherwise you can use with Garbage dispoal gimzo as long it is not over 50% of circuit capacity.
( this apply both 15 and 20 amp circuits unless your local codes don't allow it like Mike's area they will have specfic code on that )
Merci,
Marc
Old 01-22-2012, 07:21 PM   #13
Julius793's Avatar
Doesn't always say, and in that case code doesn't specify. I'm not saying it's a good idea!
Old 01-22-2012, 07:22 PM   #14
Mike .,
Belive or not in France I just got done with one kitchen remodel and we have to use 4 circuits allready and keep in your mind this is a 240 volts system.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
oh'mike (01-23-2012)
Old 01-22-2012, 07:26 PM   #15
Julius793's Avatar
Originally Posted by frenchelectrican
Mike .,
Merci,
Marc
What amp line 10 or 16?
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 03:43 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 10:13 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 06:35 PM
