Adding Clamps To Wires Entering Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 10:05 AM   #1
Adding clamps to wires entering service panel
How big of a job is it to add clamps to the wires entering the service panel shown below? Would it require removing the panel? Could I do it myself having only minimal electrical experience? How is it done? Thanks!
tomsmyth is offline   Reply With Quote
Old 11-02-2012, 10:26 AM   #2
Rewards Points: 128
It will not be easy with the type shown. They make plastic ones that snap in. You could install these backwards.
Old 11-02-2012, 10:28 AM   #3
Estimates on how much an electrician would charge to do it?
Old 11-02-2012, 10:33 AM   #4
Rewards Points: 13,458
Why would you pay someone to do a 5 min. and less then $5.00 job?
http://www.bing.com/images/search?q=...0EF728C1420929
Code05 (11-02-2012)
Old 11-02-2012, 10:35 AM   #5
Would I have to disconnect all the wires from the breakers and rethread them through the clamps? Or can I somehow do it without disconnecting?
Old 11-02-2012, 12:27 PM   #6
Most connectors go on from the outside of the enclosure. There is one connector that is made to go on from the inside, it is perfect for your situation: http://www.hubbell-raco.com/feat_item.aspx?feature=16
Home Depot carries these.
Yes, you will have to disconnect the cable from the breaker and neutral/ground bar/s and slide the connector over it.
Flaps is offline   Reply With Quote
The Following 2 Users Say Thank You to Flaps For This Useful Post:
Code05 (11-02-2012), ddawg16 (11-02-2012)
Old 11-02-2012, 12:44 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
This is what you want to use.
No need to remove wires.
http://store.alliedinnovations.com/a..._large5122.jpg
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Code05 (11-02-2012)
Old 11-02-2012, 01:16 PM   #8
Thanks everyone!
Old 11-02-2012, 01:23 PM   #9
Code05's Avatar
Rewards Points: 1,104
I will do it for $4999.99 plus travel/gas.
Whadda ya say? Deal?
Code05 is offline   Reply With Quote
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 08:00 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
200 amp service panel location question stevo1213 Electrical 10 10-27-2011 04:03 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
