-   -   Adding clamps to wires entering service panel (http://www.diychatroom.com/f18/adding-clamps-wires-entering-service-panel-161942/)
tomsmyth 11-02-2012 10:05 AM
How big of a job is it to add clamps to the wires entering the service panel shown below? Would it require removing the panel? Could I do it myself having only minimal electrical experience? How is it done? Thanks!
http://i.imgur.com/OCTMx.png
J. V. 11-02-2012 10:26 AM
It will not be easy with the type shown. They make plastic ones that snap in. You could install these backwards.
tomsmyth 11-02-2012 10:28 AM
Estimates on how much an electrician would charge to do it?
joecaption 11-02-2012 10:33 AM
Why would you pay someone to do a 5 min. and less then $5.00 job?
http://www.bing.com/images/search?q=...0EF728C1420929
tomsmyth 11-02-2012 10:35 AM
Would I have to disconnect all the wires from the breakers and rethread them through the clamps? Or can I somehow do it without disconnecting?
Flaps 11-02-2012 12:27 PM
Most connectors go on from the outside of the enclosure. There is one connector that is made to go on from the inside, it is perfect for your situation: http://www.hubbell-raco.com/feat_item.aspx?feature=16
Home Depot carries these.
Yes, you will have to disconnect the cable from the breaker and neutral/ground bar/s and slide the connector over it.
sublime2 11-02-2012 12:44 PM
This is what you want to use.
No need to remove wires.
http://store.alliedinnovations.com/a..._large5122.jpg
tomsmyth 11-02-2012 01:16 PM
Thanks everyone!
Code05 11-02-2012 01:23 PM
I will do it for $4999.99 plus travel/gas.:jester:
Whadda ya say? Deal?
