Adding Circiut Breaker Wire Outside Of House - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 09:19 PM   #1
adding circiut breaker wire outside of house
I really need some advice please. I'm in the middle of a bathroom renovation. The electrician ran the wire for a new breaker outside of the house. Is this a common practice? I'm very disappointed about this. I expected the wire to be fished through the walls (two stories) and into the attic. Not only does it look horrible, but now he has drilled holes through the stucco. He also left the entrance to the breaker box exposed. any comments or suggestion would be appreciated.
adding circiut breaker wire outside of house-photo-77-.jpg   adding circiut breaker wire outside of house-photo-78-.jpg
marieb is offline   Reply With Quote
Old 03-09-2013, 09:22 PM   #2
Rewards Points: 83
Oh my word.... talk about a hack We he licensed?
mech_gui is offline   Reply With Quote
Old 03-09-2013, 09:23 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
They should have consulted you before running the wire in this manner. Was the EC hired by the GC? Consult the GC. Was the EC hired by you? Check the contract then consult the EC.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (03-09-2013)
Old 03-09-2013, 09:25 PM   #4
TTW
TTW's Avatar
Unbelievable, was this inspected? Is it at least wet location (UF) wire?
Hack job if you ask me!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 03-09-2013, 09:39 PM   #5
Yes he is licensed. The sad thing is I have used this electrician before.
Old 03-09-2013, 09:41 PM   #6
I thought the exact same thing, that he should have consulted with me. I did bring this to the attention of the contractor. He is going to see that it is done the right way.
Old 03-09-2013, 09:43 PM   #7
That's a good question about the wire for a wet location. I will make sure to ask!
Old 03-09-2013, 10:00 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
My thoughts exactly.
The Following User Says Thank You to Speedy Petey For This Useful Post:
marieb (03-09-2013)
Old 03-09-2013, 10:04 PM   #9
Rewards Points: 12,794
I'm just a hick hack and would have known better then that.
If I walked up and saw that one one of my jobs he'd never set foot on another one and I would not pay him.
marieb (03-09-2013)
Old 03-09-2013, 10:31 PM   #10
Thank you to everyone taking the time to comment. I'm just sick over this. I know I'm pretty particular about things and this has just about sent me over the edge. Not only am I worrying about it being done correctly, but also about repairing all the holes that were drilled. Nothing is ever the same once it has been damaged
Old 03-09-2013, 10:35 PM   #11
Rewards Points: 83
I don't think you are in any immediate danger. It does need to be fixed and you should NOT have to pay for it. It looks like the stucco is kind of high in the air so any patch work will probably pretty hard to see.
Although you will know its there Dot let you GC forget that.
Old 03-09-2013, 10:44 PM   #12
Thanks for the encouragement. I worry about water now seeping in over time.
Old 03-10-2013, 12:28 AM   #13
I want to be prepared to respond to my contractor if it's suggested that fishing the cable is difficult given that it has to travel from the basement up two stories to the attic. What are any thoughts about passing the cable through conduit that could be placed along side the gutter? My first choice is to run it inside the house. I just want to have an educated decision if problems should arise.
Old 03-10-2013, 01:05 AM   #14
k_buz's Avatar
Inform them that you'd be willing to pay for a little drywall repair instead of what was installed. However, I wouldn't let him know that right away,
marieb (03-10-2013)
direct bury wire from house to garage??? help vinylman70 Electrical 30 01-20-2010 10:44 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 02:02 PM
Main house breaker keeps tripping cosmicmah Electrical 20 01-22-2008 01:36 AM
