Adding Ceiling Fan Without Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 03:48 PM   #1
Adding Ceiling fan without wall switch
I have a two story house. In my office downstairs, there is no overhead light or wall switch. However, I want to add a ceiling fan/light to this room. This is what I'm thinking of doing, but I don't know if it is okay to do..........
In the room above the office, there is an outlet in a fairly convenient place in one of the walls. Can I run wire from this outlet to my ceiling fan in the office, then run another wire from the ceiling fan to the next outlet in the chain back upstairs. So basically inserting a ceiling fan/light in the middle of a chain of regular outlets. The ceiling fan/light would have constant on power, but I would use a remote control to power it on and off, eliminating the need for a wired wall switch.
Has anyone done this before? Would this work? Thanks.
bennyhann is offline   Reply With Quote
Old 01-02-2012, 03:52 PM   #2
Rewards Points: 6,652
No, I wouldn't. With all of that trouble, you are better to just come off of an existing lighting circuit, and put in a Switch leg. You have to cut in a fan box to hold the fan up, so while the ceiling is open, it will make it easy to pull the wiring.
Old 01-02-2012, 04:03 PM   #3
I know it sounds kind of like a pain, but the way the room is laid out, there isn't a lighting circuit near where the ceiling fan is going. The closest electricity without having to drill through cross beams and such is from this outlet upstairs. It's almost directly above the fan location. So knowing this, is it safe to add a constant on fan/light in the middle of a outlet chain?
Old 01-02-2012, 04:09 PM   #4
Again, I would not do that. Best way is to cut panels out of the ceiling, pull wire from an existing lighting circuit. Done that way all of the time.
Old 01-02-2012, 04:19 PM   #5
MarginallyQualified
Rewards Points: 2,464
Worse things have been done with no serious damage to life or limb.
Before you cut open walls or ceilings (some is inevitable btw)...
invite your handiest neighbor over to verify your dire description.
Whichever way the joists run in that room...
look for another ceiling fixture in the next room over.
hth
Tags
ceiling fan , outlet , switch
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 07:24 PM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-14-2009 12:09 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Wall switch for Ceiling Fan / Light Bocolo Electrical 3 03-08-2009 10:56 PM
