Adding Ceiling Fan To Switched Outlet Keeping Switched Outlet. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 02:44 PM   #1
Doug
Adding ceiling fan to switched outlet keeping switched outlet.
This may not be possible but I currently have a switched outlet with one black wire and one white wire at the switch. There are two white and two black wires at the outlet with the hot (black) side split. Can I add a ceiling fan with second switch? One switch handling both the outlet and the fan light and the second switch handling the fan? It would seem I need to add a power wire to the fan box (not there currently) to handle the fan power.
-Thanks-
dhanawa1 is offline   Reply With Quote
Old 07-06-2011, 05:52 PM   #2
joed's Avatar
Rewards Points: 11,598
Where are you planning to connect the fan? If you intend to run the cable to the receptacle then you need to add another wire to the switch box. Two wires to the switch box is only enough to switch one device.
If you intend to run the fan cable into the switch box then you need to find a power source to run to either the fan or the switch box. The two wires in the switch box are both hots. There is no neutral wire present even though there is a white wire. The white in this case is being used to bring power to the switch.
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 07:20 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 08:00 PM
Outside: Adding an outlet to a switched light fixture indigo Electrical 9 12-15-2009 10:48 AM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 01:07 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
