Adding A Ceiling Fan To Living Room - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2008, 01:58 PM   #1
Rewards Points: 101
I'm considering adding a ceiling fan to my living room. Preferably one without a light on it. The current overhead lighting in my living room consist of 5 recessed lights. Looking up at the ceiling they are in the following pattern:
0 0
0
0 0
I was considering adding the fan between in the center of the 5 lights. I was just wondering where I would need to start as far as electrical pick-up, etc.
jte1130 is offline   Reply With Quote
Old 05-28-2008, 03:05 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I would check to see if the light circuit (hot, neutral, and ground) is presently in the switch box for the lights. If it is, you can expand the box, put in a control for the fan, and run a circuit to the new fan box. Or call in an electrician to do the job.
John
jrclen is offline   Reply With Quote
Raising step down living room questions phil. Building & Construction 10 02-05-2015 11:39 PM
Adding a 2nd story floor to vaulted living room sebastien1 Remodeling 15 05-17-2008 06:45 AM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Living room colors-Yellow, White, Sage or Taupe Minak Painting 22 02-21-2007 02:31 AM
