Adding Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 12:12 PM   #1
Adding Can lights
Hi all, Newbie here
I originally had the ceiling fan and the switch. I started to add the can lights and got busy with life. Now months later I'm not sure what to do.
Can someone tell me how to connect these wires?
Do I have to many for a 4 way box?
Should I forget about the can lights?
Any help would be greatly appreciated.
Stevo-1 is offline   Reply With Quote
Old 12-15-2012, 06:25 PM   #2
Rewards Points: 320
That depends on how you want the lights controlled. Are you going to have all of the lights on one switch along with the fan?
Need more information. How deep is the box? What wire size are you using? Are there internal cable clamps or external? Do you have access above this area such as an attic?
That depends on how much you want/need the additional can lights. Even if it turns out that you can't use the existing box doesn't mean that the project is over. Sometimes you just need to find another way. Can you run the cable from one can light to the other and not use the existing box. That would save you a couple of conductors towards the box fill.
teamo is offline   Reply With Quote
Old 12-15-2012, 07:46 PM   #3
Re:
Thank you for the reply
Yes that would work I can control the fan with the pull chains independently
2"
14/2
External
Yes Attic
Yes, why didnt I think of that.
Old 12-15-2012, 07:51 PM   #4
Revised
Revised
Old 12-16-2012, 01:47 PM   #5
Rewards Points: 320
Looks like that should work for you. I don't have my book with me but from memory that box is good for 15 #14 wires. External clamps don't count towards fill. You have 5 cables which is 10 wires+1 for all of the grounds. The fan wires will have to be counted and I am not sure if the fan fixture itself would take up any of the conductor count. A device like a switch or an outlet counts as 2. If the box gets too full you could install a new 4" square box next to this box.
Adding Additional Recessed lights to existing jay235 Electrical 5 11-08-2012 06:43 PM
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
adding lights samiller1980 Electrical 2 03-28-2010 07:45 PM
Adding Motion Sensor to coach lights sstinman Electrical 2 09-22-2009 10:44 PM
