Old 04-12-2006, 01:53 PM   #1
Adding a breaker to a sub panel...PICS
I need to add a 220 breaker and outlet to this subpanel. From what I have read it should have a ground bar and a neutral bar. it appears to only have a neutral bar. Can someone clarify this for me? Also if you happen to know exactly what brand/model of breaker I need from looking at the pic I would appreciate it.
freakaccident is offline   Reply With Quote
Old 04-12-2006, 04:09 PM   #2
Doing it myself
Alan's Avatar
I'm no expert, but i'm guessing the ground is attached to the box itself? Don't take my word however, wait for someone a bit more experienced. I've only ever worked with BASIC 110v electrical, like adding outlets and switches and things like that.
Old 04-13-2006, 07:29 AM   #3
Electrical Contractor
As I replied in the other forum. you need to add a ground bar kit that is made for this panel. The cover will have the brand, then you will know what type of breaker.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-13-2006, 05:25 PM   #4
As I replyed in another forum. You can use a generic ground bar if you drill and tap the screw holes for machine screws. and It is a generic siemans panel and will take any breaker classified for a siemans panel.
jwhite is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
breaker panel Ehren51 Electrical 1 01-28-2004 08:43 PM
