Adding A Breaker To Main Lug Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 07:29 AM   #1
Question
Adding a breaker to Main Lug Panel
My home's load center is a 200 amp Square D main lug panel. I want to add a new 20 amp circuit to the panel. The panel appears to have one space remaining, but someone placed a sticker on the twistout that states "If lugs at top DO NOT REMOVE THIS TWISTOUT." Does anyone know why this sticker would have been applied to the last remaining twistout in the panel cover? Does it just mean that if there are any remaining spaces above, those should be used first? Would there be any reason why I can't add a breaker if there is a remaining space?
Thanks for your assistance.
kst43368 is offline   Reply With Quote
Old 12-12-2011, 07:36 AM   #2
joed's Avatar
Rewards Points: 13,368
The last remaining twist out could be the one for the main breaker which is not used with main lug.
Old 12-12-2011, 07:48 AM   #3
That seems plausible, but why would there be space for a main breaker in a main lug panel? By definition, a main lug panel doesn't have a main breaker, correct?
Also I would assume that the twistout for a mian breaker would need to be larger than the remaining twistout is (only a 15 or 20 amp breaker would fit, I believe).
Old 12-12-2011, 09:59 AM   #4
joed's Avatar
Some panels are dual function. It depends on how you set them up.
I was only guessing. Post a picture so we can get a better idea.
Old 12-13-2011, 12:14 PM   #5
Pics
Here are some pics. Apologies for the poor quality. You can see the last open space is the bottom one on the right hand column. The last photo shows the sticker I was referring to in my first post. Thanks, again, for your assistance.
Adding a breaker to Main Lug Panel-panel1.jpg   Adding a breaker to Main Lug Panel-panel2.jpg   Adding a breaker to Main Lug Panel-panel3.jpg
Old 12-13-2011, 03:03 PM   #6
Julius793's Avatar
Can u post a pic of the bus where the breaker would sit? Personally if the bus looks normal I wouldn't be concerned and I think the sticker was misplaced
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-13-2011, 03:30 PM   #7
Sparky
Rewards Points: 510
i cant tell what the top line says on the sticker, this also looks like a split bus panel..
Techy is offline   Reply With Quote
Old 12-13-2011, 05:29 PM   #8
Sorry for the unclear picture of the sticker. It says, "If lugs at top DO NOT REMOVE THIS TWISTOUT."
I don't see anything out of the ordinary with the bus where the breaker would sit. However, I talked to my neighbor, and he has the same sticker in the same location on his panel (I live in a townhome community). Since I've already fished the wire and all that needs to be done is to have a new breaker added to the panel (or to have a subpanel added if I can't use that space), I think I'll suck up the cost of getting an electrician. I always get a little nervous sticking my fingers into a service panel anyway...
I really appreciate all your assistance.
Old 12-13-2011, 05:31 PM   #9
Master Electrician
Rewards Points: 3,920
That is not a useable breaker space. Look at the buss.
brric is offline   Reply With Quote
Old 12-13-2011, 07:06 PM   #10
It may not be usable, but there is no question a Square D 20 amp breaker will attach and fit in that space. It's not a matter of the buss not extending that far or being unable to accept a breaker in that spot.
Old 12-13-2011, 07:10 PM   #11
My photos are worthless. I tried uploading photos from my camera, but I got a message saying the files were too big. So I used my phone's camera instead, which isn't a good camera (I'll accept some blame as the operator as well).
Old 12-13-2011, 08:04 PM   #12
VA master electrician
It looks like a usable busbar stab-in for a single-pole breaker. Check with the panel tech support folks to be sure.
VA master elect is offline   Reply With Quote
Old 12-13-2011, 09:02 PM   #13
joed's Avatar
Resize the image before you try to upload it or set your camera to a lower resolution so the image is not so big.
Old 12-13-2011, 11:54 PM   #14
Missouri Bound's Avatar
I completely agree....that space is not usable for a breaker.
The Following User Says Thank You to Missouri Bound For This Useful Post:
brric (12-14-2011)
Old 12-14-2011, 05:25 AM   #15
Master Electrician
Tandems are available for SQ D QO panels. BTW, is this a sub panel? If so, why are the neutrals and equipment grounding conductors not separated?
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 01:56 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
