Adding Breaker To Fuse Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 05:32 PM   #1
adding breaker to fuse box
i have a house with 2 air conditioners when they are both on it pops the breaker half the house goes out ....how do i figure out where the plug wires go to??
Jeremy25 is offline   Reply With Quote
Old 07-23-2010, 06:06 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Jeremy
The title of your thread suggests you want to install a breaker. Are you wanting to install a bigger breaker in place of the existing one? Can you give us more details?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-23-2010, 07:51 PM   #3
Electrician
Proby's Avatar
The next time you use both air conditioners and a breaker trips, go around the house and find a receptacle that is still working. You need to move one of the air conditioners to this area and plug it into this receptacle.
Other than that, call an electrician. Don't do the old "install a bigger breaker/fuse" idea that many people have used to burn their house down.
Proby is offline   Reply With Quote
Old 07-23-2010, 08:09 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
What does it matter? Obviously half the house is on one circuit.
You need to have an electrician run a new circuit, or two, to ease the load on that existing circuit.
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 07:24 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
