Old 10-04-2009, 04:50 PM   #1
adding another light to 3 way
How do i add another light to a 3 way circuit. It lloks like the power goes to the switch, then the light, and then the other switch. How can i add another light
burk11 is offline   Reply With Quote
Old 10-04-2009, 04:55 PM   #2
300zx's Avatar
Post
Do you have attic acess? what kind of light are you adding? What kind of lights are there now?
300zx is offline   Reply With Quote
Old 10-04-2009, 05:00 PM   #3
i have lights on a pull chain in my basement now.i am trying to add a regular light to a 3 way switch that controls the light at the bottom of the stairs
Old 10-04-2009, 05:05 PM   #4
300zx's Avatar
Post
is the ceiling done alread bucause yo will need some way protect the wie?And the 3 wire going from the top of sataire to bottom of staires
Old 10-04-2009, 05:06 PM   #5
yes it is
Old 10-04-2009, 05:18 PM   #6
300zx's Avatar
Post
So you know the wire cant be subject to anywhere it can be damaged Any way pt one box on the top of sateis and do the same at the bottom Run a 12-3 romex inbetween both boxes the first box ant the top of the stairs you need power 120 volt in that box. The bow at the bottom of stairs run 1 -12-2 romex to the first light. Now you need to open that light box TURN POWER OFF A USE A FLASHLIGT You need a volt tester os a volt stick to find your hot (feed)wirenut it off and tuck into box Conect your new wire grounds to grounds White to White And the new black where the othe one you capped of was conected to.Your new feed wil be the common on rec others are travelers .At the second 3 way the back from light goes on that ones common and other two are travelers
Old 10-04-2009, 05:20 PM   #7
thx , i thinkg that helps
Old 10-04-2009, 05:30 PM   #8
300zx's Avatar
Post
If you need more advice there are alot of good people here that will also help have you thought about remote lighting just a thought.Keep us updated and we can work you through this
Old 10-04-2009, 05:32 PM   #9
joed's Avatar
With the setup you describe you must pull the cable for you second light to the existing light. You can't make the connection at either switch box.
Do not PM with questions that can be asked in a forum. I will not respond.
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Adding 15 amp light and switch on a 20 amp circuit Jzack26 Electrical 1 08-02-2009 05:02 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
