Adding Additional Recessed Lights To Existing - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 12:51 PM   #1
Rewards Points: 35
Adding Additional Recessed lights to existing
Hello Fellow DIYers,
I have 2 recessed lights in my kitchen that is connected to a single light switch. I would like to add another 2 recessed lights by attaching another wire to the junction box of each light and running a wire some 15 feet parallel to the joists.
My question is, how can I do this without cutting out the drywall? Can I somehow remove the existing recessed light housing to access the wiring junction box? The existing lights were installed by the builder using new home construction recessed lights ( The one's with the bars on each side with a separate junction box). Attached is a diagram of what I propose.
Thanks in advance.
jay235 is offline   Reply With Quote
Old 10-15-2012, 08:47 PM   #2
Licensed electrician
Rewards Points: 1,250
Typically there are 3 small screws that can be removed to allow access to the junction box on the fixtures. You could then push the cables down the joist bay.
Old 10-15-2012, 09:25 PM   #3
Resi EC
Rewards Points: 252
After removing the the recess housing, I have used my phone to take a picture down a space just to make sure there are no obstacles blocking the path of wire and proposed location of new recessed light.
Gac66610 is offline   Reply With Quote
Old 10-16-2012, 09:17 AM   #4
Rewards Points: 35
Thank You. I will give that a shot.
Old 11-08-2012, 06:37 PM   #5
Rewards Points: 35
Turns out that there is a firewall (wood perpendicular to the studs) in between - down about 6 feet from the light. What is the best method to run a wire through that? Is my only option to cut the drywall by the firewall and drill a hole to run the cable?
Old 11-08-2012, 06:43 PM   #6
That is probably just solid bridging. You should be able to drill it.
Need Help Adding Switches and New Lights JCWarrior Electrical 6 11-16-2011 06:45 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Commercial Electric vs. Halo recessed lights bubbler Electrical 0 10-12-2011 08:06 PM
How Many Recessed Lights SHould I use? jonathan03 Electrical 0 03-15-2010 12:03 AM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
