-   -   Adding Additional Recessed lights to existing (http://www.diychatroom.com/f18/adding-additional-recessed-lights-existing-160174/)
jay235 10-15-2012 11:51 AM
1 Attachment(s)
Hello Fellow DIYers,
I have 2 recessed lights in my kitchen that is connected to a single light switch. I would like to add another 2 recessed lights by attaching another wire to the junction box of each light and running a wire some 15 feet parallel to the joists.
My question is, how can I do this without cutting out the drywall? Can I somehow remove the existing recessed light housing to access the wiring junction box? The existing lights were installed by the builder using new home construction recessed lights ( The one's with the bars on each side with a separate junction box). Attached is a diagram of what I propose.
Thanks in advance.
Jim Port 10-15-2012 07:47 PM
Typically there are 3 small screws that can be removed to allow access to the junction box on the fixtures. You could then push the cables down the joist bay.
Gac66610 10-15-2012 08:25 PM
After removing the the recess housing, I have used my phone to take a picture down a space just to make sure there are no obstacles blocking the path of wire and proposed location of new recessed light.
jay235 10-16-2012 08:17 AM
Thank You. I will give that a shot. :)
jay235 11-08-2012 05:37 PM
Turns out that there is a firewall (wood perpendicular to the studs) in between - down about 6 feet from the light. What is the best method to run a wire through that? Is my only option to cut the drywall by the firewall and drill a hole to run the cable?
Jim Port 11-08-2012 05:43 PM
That is probably just solid bridging. You should be able to drill it.
