Adding Additional Outlet To GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 03:17 PM   #1
adding additional outlet to GFCI
There are no black wires connected to the GFCI outlet , only a red one and a white one. Do we assume that the red one is the same as a black wire?
John Troxel is offline   Reply With Quote
Old 08-28-2011, 03:23 PM   #2
Licensed electrician
Rewards Points: 996
Any color besides white, green, green with a yellow stripe can be a hot conductor. Your red is the same as the black you would typically see.
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
adding outlet from light switch tad Electrical 17 06-06-2009 12:25 AM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 02:49 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
