Adding 40amp Double Pole 240v - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 05:56 PM   #1
adding 40amp double pole 240v
What do I need to look for in the main breaker if I am adding a 40amp double pole breaker to it. Do i need to do any calculations for the main breaker before putting in the 40amp double pole breaker? What size wire is recommended. Would an 8/2 romex be safe enough?
watsupbud is offline   Reply With Quote
Old 11-08-2010, 06:03 PM   #2
Rewards Points: 1,214
Depends what are you planning ? More info would be helpful.
COLDIRON is offline   Reply With Quote
Old 11-08-2010, 06:47 PM   #3
joed's Avatar
Rewards Points: 11,614
First thing you need to look for is two empty spaces in your panel to add the breaker.
Old 11-08-2010, 07:09 PM   #4
New stoves require a neutal, so 40amp...u need 8/3
heartlessmcfly is offline   Reply With Quote
Old 11-09-2010, 06:55 AM   #5
Did not see any mention of stove.
Old 11-09-2010, 07:40 AM   #6
Rewards Points: 1,418
A 40 amp breaker requires an 8 gauge or fatter wire (copper) for the circuit it serves.
Check the place in the panel to be sure that the two fins on which the breaker will fit on have 240 volts across them (are on opposite sides of the 120./240 volt service).
Sometimes you may have to rearrange other breakers to do this.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 06:15 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
