Adding 3 Prong GFI To Old Wiring Where None Existed Before - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 09:09 PM   #31
Rewards Points: 6,652
crescere, you need to check with your local AHJ, due to not all allow these to be used (ie Chicago).
Old 11-06-2013, 09:20 PM   #32
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Those tyco splice kits should be thrown into the backstabbing category, they fail just as often, funny how people think about certain products.
The Following User Says Thank You to stickboy1375 For This Useful Post:
k_buz (11-06-2013)
Old 11-06-2013, 09:24 PM   #33
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Honestly, I don't see how those are legal to be concealed.
Old 11-06-2013, 09:26 PM   #34
E2 Electrician
I don't get it either, but I've read enough about them that they are, personally, I would use a UF splice kit over one of those Tyco kits if I absolutely HAD to do the dirty deed….
Old 11-06-2013, 09:27 PM   #35
k_buz's Avatar
I'm not going to say what I would do...although, I've done a TON of remodels and never had the need to bury a box/splice.
The Following User Says Thank You to k_buz For This Useful Post:
Know A Little (11-09-2013)
Old 11-06-2013, 09:28 PM   #36
E2 Electrician
no worries, your sins are forgiven…
Old 11-06-2013, 10:57 PM   #37
The Tyco's & NSi's are legal to be concealed, the Ideal "Splice-Line" are not, due to they are made for only to be used in Raceways, or inside Junction boxes.
Old 11-06-2013, 11:05 PM   #38
Rewards Points: 34
Originally Posted by crescere View Post
How do you and others do these drawings and then post them here?
I used Microsoft Visio to make this one, then saved as an image. Didn't have any stencils that represented physical outlets or switches, so I built them using various shapes that I sized and filled accordingly.
You can find how to post in the Chatroom's FAQ for Posting New Messages, in the section on Attachments and Images.
Anyone care to comment on the correctness of my wiring diagram? I'm going to be ripping into things in a couple of days, and will only have a short time to get 'er done, so having this figured out before hand will save a lot of time.
Thanks,
DBB1959
DBB1959 is offline   Reply With Quote
Old 11-06-2013, 11:15 PM   #39
I see no problem with your diagram, other then I would make the GFCI feeding the medicine cabinet light & outlet, vs. leaving the outlet in the cabinet unprotected.
Old 11-06-2013, 11:54 PM   #40
Rewards Points: 34
Thanks, gregzoll.
No, the current cabinet and light (with its outlet and push button switch) are all coming down and getting pitched. The new switch for the light and the new outlet will be down on the wall, at regular switch height (the gray box that they are both in was my pitiful representation of a double-gang box, not the cabinet...). No plans to put anything electrical in the new cabinet.
The source wiring, new j-box, and new light fixture will all still be up above the replacement cabinet, where the old light is located now.
Old 11-07-2013, 12:05 AM   #41
Can you post a picture of your setup that you are dealing with. Also if you do like I did, it makes things a whole lot easier when you have a nightlight plugged in, room freshener like the Air Wick, that my wife keeps plugged in on the outlet to the right, and a rechargeable razor like I do, which is always plugged into the left outlet.
There is no such thing as too many outlets in a bathroom. Same goes for a Kitchen.
Old 11-07-2013, 12:34 AM   #42
Rewards Points: 34
The job is out of town, so nothing I can post as of yet.
Right now, the only outlet she has anywhere close to the sink area is the one that's built into the end of the old fluorescent fixture. There is only one other outlet in the entire bathroom, on an opposite wall, at regular outlet height from the floor. Trust me, this will be an improvement.
Maybe this will give a better idea of what I'm proposing. The new outlet/switch location is approximate, but hopefully will show what I'm trying to accomplish for switching the new light, once I pull and replace the old one:
The Following User Says Thank You to DBB1959 For This Useful Post:
gregzoll (11-07-2013)
Old 11-07-2013, 09:38 AM   #43
Rewards Points: 664
There have been many times where the prior home owner just twisted the wires together with tape and left them behind a wall. Often I want to tile over the wall like in a kitchen. Having an ugly box in the middle of the wall with just a blank cover does not look good. Certainly using one of these devises is better than what the prior home owner did!
I know that this idea goes against what many of you believe, but if it is safe I want to start using it.
crescere is offline   Reply With Quote
Old 11-07-2013, 09:41 AM   #44
k_buz's Avatar
You are missing the point. Of the wall is open, there should be no need for a JBox. Replace the cable/s or disconnect the feed and refees what it was going to.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Jim Port (11-07-2013), stickboy1375 (11-07-2013)
Old 11-07-2013, 04:16 PM   #45
Rewards Points: 664
I am saying that I encounter many situations where I find that prior owners have just spliced together two wires and left them in the wall taped together. I want to work fast by putting in the necessary GFCIs (if it is a kitchen or bath) and then make the wall look good. With these devices I can be sure the splice is safe and just move on. I do not want to replace an entire line if I don’t have to. I think that explains my situation. I did not know these things existed.
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Dryer 3 prong to 4 prong wiring question neondeception Appliances 5 05-02-2012 10:11 AM
Dryer - 4 prong to 3 prong majorwest Electrical 15 02-06-2012 05:03 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 11:20 AM
