Adding 3 Prong GFI To Old Wiring Where None Existed Before - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2013, 04:04 PM   #16
Rewards Points: 79
Originally Posted by DBB1959 View Post
That was Know A Little's experience, too, in the other post. Maybe I'll get lucky in that regard, otherwise I'll just be using a GFI marked accordingly.
My big concern is still getting the (possibly too short) wiring down to where I want to put a switch for the new lights.
It just dawned on me that I could use the junction box of the lighting fixture to add the extra length of wiring down to the switch (and back up to the new light above the cabinet). Might be a bit crowded in the box. But my junctions would be in an accessible j-box, but just hidden behind by the lighting fixture. That way I would not have to have an exposed blank plate on the wall where I add onto the length of wiring.
Anyone see any code issues with this?
you dont need to run that old wire down to the switch. Leave it where it is and put it in a box that you will mount your new fixture to. From there, run a 3 wire down to your double gang box for your switch and GFCI receptacle.
As for the receptacle itself..like others have said, you need to verify that you do or do not have a ground wire in that old cable.
EDIT: Misread your post, yes you can do that and there's nothing wrong with it. Just know that you can run a 3 wire down to the switch/GFCI and don't have to run a cable down, and another cable back up.
tfo411 is offline   Reply With Quote
Old 11-02-2013, 04:44 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by gregzoll View Post
Actually they can, if they use the Ideal connectors.
Want to explain this a little deeper?
Old 11-02-2013, 04:49 PM   #18
Rewards Points: 79
Think he's talking about these.
http://www.homedepot.com/p/Tyco-Elec...6#.UnV01_m3-Dk
Old 11-02-2013, 05:15 PM   #19
Rewards Points: 6,652
Originally Posted by tfo411 View Post
NSi Industries also makes something similar, but not as large.
Old 11-03-2013, 06:22 AM   #20
E2 Electrician
Few issues come to mind with this, Is the wiring method even NM, and if so, does it contain an equipment ground?
Old 11-03-2013, 06:26 AM   #21
E2 Electrician
2) I won't know until I pull out the cabinet how much slack I have with the existing wiring. My guess is that I would have to add to it to give me the length needed to reach the new outlet & switch further down the wall (to the same height as the other switches in the room).
What are the rules for doing an in-wall splice?
I know any connection needs to be in a j-box, but can that j-box stay hidden in the wall, or do I need to make it accessible and put a blank cover plate on it? I suppose the other option would be to put the GFI in that single-gang j-box with the original wiring, then feed new wiring from it down to the switch and up to the new lights.
I don't like the idea of a blank j-box cover or GFI high up on the wall - obviously only having the 2-gang switch/outlet would be the most attractive.
DBB1959
You can install a junction box in the vanity cabinet, thats a good place for one, or cut in a box in the adjoining room….
Old 11-06-2013, 12:13 AM   #22
Rewards Points: 34
Yeah, that makes sense... I was thinking that I would have to take both the neutral and hot down to the switch, but it took me a while to get my head around what you're saying.
Can you guys take a look at my drawing and see if I have this right? I don't want to burn me Mum's house down...
Adding 3 Prong GFI to Old Wiring Where None Existed Before-light-switch-outlet.jpg
My drawing doesn't show a ground wire because the house only has two prong outlets. Of course, if I get lucky and her original 1960 wiring has an unused ground (as others have posted may be the case for this time period house), I'll tie them together and test.
Thanks!
DBB1959 is offline   Reply With Quote
Old 11-06-2013, 08:40 PM   #23
Rewards Points: 664
I just googled Ideal connectors and it appears to be a wire not company that makes both twist on and the push in type. Do you mean that if one uses the push in type i can leave the connection in a wall without a box?
crescere is offline   Reply With Quote
Old 11-06-2013, 08:42 PM   #24
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
No...
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (11-06-2013)
Old 11-06-2013, 08:43 PM   #25
Rewards Points: 664
Thanks!
How do you and others do these drawings and then post them here?
Old 11-06-2013, 08:44 PM   #26
Rewards Points: 664
Originally Posted by k_buz View Post
No...
So was the prior poster wrong?
Old 11-06-2013, 08:47 PM   #27
k_buz's Avatar
He was talking about a different type of connector. I believe he was mistaken on the manufacturer.
Old 11-06-2013, 08:49 PM   #28
Tyco & NSi make the in wall connectors in question. Ideal do have one, but it is not rated for in-wall use, without being placed into a electrical junction box.
Old 11-06-2013, 08:56 PM   #29
Fingers were quicker then the words getting typed in. I was thinking of the Ideal "Splice-Line" connectors when I typed that in at first, not the one that NSi & Tyco makes. The Splice-line are not rated for in-wall w/o junction box, mainly for raceways.
Old 11-06-2013, 09:07 PM   #30
Rewards Points: 664
Ok, so this http://www.homedepot.com/p/Tyco-Electronics-Romex-Splice-Kit-2-Wire-1-Clam-CPGI-1116377-2/202204326
something I could use for old work where I need a splice instead of a junction box? This would really be helpful!
New Home: 2 Prong Outlets & K&T Wiring (Maybe) weekley14 Electrical 4 05-29-2012 07:56 AM
Dryer 3 prong to 4 prong wiring question neondeception Appliances 5 05-02-2012 10:11 AM
Dryer - 4 prong to 3 prong majorwest Electrical 15 02-06-2012 05:03 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
adding copper pigtails to my aluminum wiring was worth it ntomlin Electrical 7 03-02-2009 11:20 AM
