Adding 2nd Floor Circuit By Running Wires Outside In PVC - Advice? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 10:22 AM   #16
Electrician
Proby's Avatar
Originally Posted by secutanudu View Post
How do you seal the pipe where it goes outside? You are talking about sealing the inside of the pipe, right? I have a 1" pipe leaving my basement underground (about 12" below grade) to my lamppost. I did not seal the inside...caulk? foam?
Condensation could form inside the pipe. Ground water can also come thru if it wasn't glued well. You don't want that water coming into your basement so sealing the pipe is a good idea.
You can use duct seal for this purpose, or just fill it up with goobs of silicone. Both of those are removable in case you ever have to repair a broken pipe or pull another set of wires into the pipe.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 10:32 AM   #17
Just call me Andrew
Rewards Points: 1,020
I'll put some silicone in tonight. Thanks.
Andrew
secutanudu is offline   Reply With Quote
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Adding radiant heating to basement bath. Need advice. ingeborgdot Flooring 7 05-05-2008 06:40 AM
Furnace advice - adding a wood burner to forced air CowboyAndy HVAC 4 03-03-2008 10:21 AM
Adding a Sunroom - Need some advice Todd1 Building & Construction 1 02-02-2008 01:12 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 07:44 PM
