Adding 220 Line - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 02:43 PM   #1
adding 220 line
Can I add a 220 line to an existing 30 amp dbl pole breaker with an existing 220 line. panel is 100 amp with 4 20 amp breakers and 1 30 amp dbl pole and 1 40 amp dble pole.
Mikejr05 is offline   Reply With Quote
Old 06-04-2009, 02:57 PM   #2
DIY'r
ScottR's Avatar
You could replace the existing 240V line with the new one on that 30A breaker, but you cannot attach both to the breaker at the same time, no. (Called double-tapping; generally not allowed unless the model of breaker is listed for it. 30A and up are [AFAIS] never listed for it).
If you have the space in the panel, you'd have to add a new breaker for the new line.
ScottR is offline   Reply With Quote
Old 06-04-2009, 03:05 PM   #3
adding 220 line
well do I need to have 30 amp dbl pole or will 15 amp dbl pole work don't want to overload panel
Old 06-04-2009, 03:11 PM   #4
Licensed Pro
That depends entirely on what is on the circuit.
What are the other circuits?
Old 06-04-2009, 03:24 PM   #5
adding 220 line
using line for ac window unit
Old 06-04-2009, 03:36 PM   #6
well only using line for ac window unit 220 plug , what do you recommend
Old 06-04-2009, 04:21 PM   #7
DIY'r
ScottR's Avatar
What is the load of the A/C unit? (In Watts or Amps).
What is on those 2 circuits?
And are the 20A circuits all for lights and receptacles, or do you have any appliances permanently connected to those?
Old 06-04-2009, 04:45 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
OK Mike. Let's try this from the top.
You have a 240v-30a circuits and receptacle being used for an A/C unit. Correct?
You want to add another 240v receptacle to this existing line. Correct?
For what? What is the draw or circuit requirement?
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Adding 110V outlets to 220V line MarcG Electrical 25 04-29-2009 07:04 AM
Does adding a new gas line to kitchnen need permit ? kptbls Plumbing 15 01-15-2008 07:17 AM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 08:00 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 12:35 PM
