Adding 220 20A Breaker But It Trips When Turned On - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 11:18 PM   #16
Rewards Points: 12
I fixed the wires in the disconnect box. I'll get the compressor hooked up soon. Thanks for all the help. That didn't take long to correct!
mi_fiveo is offline   Reply With Quote
Old 05-18-2012, 11:26 PM   #17
Rewards Points: 6,652
Speedy, you know they make those suckers so cheap now, I was working on mine to put electrical grease on the blades, and the durn thing broke at the eye for the screw on the right side. For right now, I put the cover back on to hold it in place, until I can get a replacement.
As for the OP, make sure that you put electrical grease on the screws & the blades & contacts, while the breaker is off in the main panel. It will keep it from corroding over time. You can get the little packets at Auto-Zone or Advance Auto Parts.
The Following User Says Thank You to gregzoll For This Useful Post:
PaliBob (05-19-2012)
Old 05-19-2012, 12:30 AM   #18
Idiot Emeritus
Rewards Points: 1,492
Even though it's advertised as such, that compressor is not 5 HP. It's more like 3.
15 amps at 230 volts equals 3450 watts. 5 HP at 746 watts per HP equals 3730 watts.
If you have more watts out than you have in, you have more than perpetual motion. This is not possible.
A 20 amp breaker might hold, but maybe not. If it trips, it's perfectly code-compliant to use a 30 or 35 amp breaker with #12s to feed a 15 amp motor. It would even be compliant to use #14s with this motor and a 35 amp breaker.
Rob
micromind is offline   Reply With Quote
The Following 5 Users Say Thank You to micromind For This Useful Post:
frenchelectrican (05-20-2012), mpoulton (05-19-2012), PaliBob (05-19-2012), silversport (05-19-2012), Speedy Petey (05-19-2012)
Old 05-19-2012, 08:27 AM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
That is one of those fake 5HP motors.
We all know a true 5HP motor will pull much more than 15A @ 240v.
You would go by the 15A number, NOT the 5HP number.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 05-19-2012, 08:39 AM   #20
I=E/R
a7ecorsair's Avatar
Take it easy, I have one of those fake 5HP motors on my compressor.
It's run fine on a 15 amp circuit even in cold weather.
a7ecorsair is offline   Reply With Quote
Old 05-19-2012, 08:54 AM   #21
So do I.
Mine is the same as the OP, but it says 3.2HP on the label, NOT 5HP.
Same electrical specs, but more CFM because mine is 135psi.
Old 05-19-2012, 12:29 PM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,168
Don't you know....it's "PEAK" HP.....
Sears got into trouble with some of it's stuff with that label and their 'generous' HP ratings.
Basically, they take the initial inrush current and calculate the HP based on that.....
ddawg16 is online now   Reply With Quote
Old 05-19-2012, 12:37 PM   #23
I=E/R
a7ecorsair's Avatar
It's like stereo amplifiers. They have a peak power rating and a continuous RMS power rating. Guess what gets advertised
Old 05-19-2012, 12:46 PM   #24
Originally Posted by k_buz View Post
I do not believe a 20A circuit will be large enough for a 5 HP motor.
Even for a 100% efficient motor, you're right, and a motor this small is nowhere near 100% efficient.
5hpx746w/230v = 16A and at 85% efficiency it'd be 19A.
Any spin doctor can say 5 hp (it's not easy to verify) but all the spin doctors in the world cannot prevent an overloaded breaker from tripping (it's easy to verify).
You can complain to the FTC about this misleading advertising but almost certainly they are a Captive Regulatory Agency.
Circuit Breaker trips when system is turned on. kbsparky Electrical 0 07-07-2011 10:02 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Table Saw trips breaker - need troubleshooting help Leah Frances Electrical 6 08-26-2009 11:41 PM
breaker trips when too much is used lightone Electrical 11 04-29-2007 11:20 PM
