Adding 220 20A breaker but it trips when turned on
You did not strip enough sheath off the cable in the panel. You should have at least 6" of free conductor.
The white should also be marked as a hot with tape or a magic marker. Black or red would work.
The cable also needs to be secured within 12" of the disconnect.
