Adding 2 Switches For Fan And Fan Light - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 11:17 AM   #1
Rewards Points: 388
Adding 2 switches for Fan and Fan Light
Hello,
I currently have one light switch which operates an outlet in one of my bedrooms. I want to add a ceiling fan that has independent switches for the fan and light - but I want to make sure i'm wiring it correctly and safely.
Current (First Pic)- Live hot feeds into bottom of switch (bottom insert hole) and the all of the bedroom outlets (pig-tailed) tie into the bottom of the switch on the screw. Coming out of the top of the switch is one hot which feeds to a single outlet. All of the neutral and grounds are tied together.
New Plan (Second Pic)- Remove the constant outlet hot from the screw, add a new hot wire to the top of new switch and run a wire up to the attic for fan. Add another hot wire from the bottom of that switch to the third switch and run another wire up to the attic for the lights. Re-connect the constant outlet wire to the screw of the last switch. Connect all the neutrals and all of the grounds together.
At the top of the ceiling, connect the neutrals and grounds together with the fans neutral and ground. Connect the fan hot to the fan switch hot, and the fan light hot to the light switch hot.
Adding 2 switches for Fan and Fan Light-old.jpg   Adding 2 switches for Fan and Fan Light-new.jpg
adgjqetuo is offline   Reply With Quote
Old 04-23-2012, 01:11 PM   #2
joed's Avatar
Rewards Points: 11,520
Looks good except that you have a ground a white crossed at the fan.
Are the fan and the light two separate fixtures?
Old 04-23-2012, 01:20 PM   #3
Rewards Points: 388
They are the same fixture. I believe it has one neutral, one ground and two hots (one light one fan). I was going to fuse all three whites, all three greens and give each its own hot.
Thanks for catching the cross wires, drawing error
Old 04-23-2012, 03:23 PM   #4
joed's Avatar
Then you need to run a three wire cable. It will have one white, bare, red and black. Use the red and black as the two switched wires. The fan should have a single white and ground for both and then a black for the fan and a blue or black with stripe for the light.
This drawing doesn't have as switch on the fan but you get the idea.
Old 04-23-2012, 05:18 PM   #5
Rewards Points: 388
Ok cool. So basically the same thing, just less wires
Old 04-24-2012, 09:29 AM   #6
Rewards Points: 388
So I drew it out with the new wire, but I came to a standstill with the grounds.
Do I connect all of these grounds to the main line? If so, I'm assuming I need an individual ground wire to connect in the switches?
Old 04-24-2012, 10:02 AM   #7
Rewards Points: 2,494
are all 3 switches in the same box?
hammerlane is offline   Reply With Quote
Old 04-24-2012, 10:06 AM   #8
Rewards Points: 388
Yes, all three switches will be in one box.
Old 04-24-2012, 11:25 AM   #9
just add jumpers or pigtails to the incoming ground and attach each jumper to a switch.
Old 04-24-2012, 05:28 PM   #10
joed's Avatar
Connect all the grounds together in all the boxes.
Old 04-25-2012, 06:55 AM   #11
Rewards Points: 388
So I ran into another issue last night...I was pulling back some drywall to make room for the 3-gang box the stud to the left is 1/2" to close not making enough room for the box.
The wall is a short wall - only 12" total, so I guess the builder decided to stick a stud in the middle. I thought I would have enough room when using the stud finder, but it's clearly not the case.
So now I'm forced to use a 2-gang box instead of a 3. I thought at first my only option would be to buy a fan / light combo switch, but then I had another thought.
I don't really care to have the one outlet on the switch. Is it perfectly okay if I remove the far left switch and just add a wire lug on the hots? This would make the outlet a constant outlet, feeding from a single hot wire from the middle switch.
It just seems like a lot of "single" wires - which is a little odd to me.
Old 04-25-2012, 07:43 AM   #12
Dont know if your 2 receptacles are in the same box or separated by wall space??
Old 04-25-2012, 07:57 AM   #13
Rewards Points: 388
Unfortunately I can't daisy chain the outlets together. The outlet which was operated on the switch is on the complete other side of the room. I have no way of linking the switch outlet to the others around the room besides right here in the box.
The box only houses a light switch.
Knowing this, is my above diagram still feasible? I'm not stepping outside of code or anything?
Old 04-25-2012, 08:15 AM   #14
so the cables for each receptacle come into the switch box???
Old 04-25-2012, 08:25 AM   #15
Rewards Points: 388
I apologize, let me clarify.
3 outlets around the room are daisy chained together, and the last outlets 14/2 wire feeds into the box and connects to the bottom of the switch screw. The live feed feeds into the back of the same switch through the push wire hole.
The single outlet which operates on the switch is on the complete other side of the room. The wire goes up into the attic and back down into the box and connects to the top of the switch.
I can't connect the outlet which is on the switch to the rest of the outlets because it's in the wall on the other side of the room. I can only connect it through the box itself.
Does this diagram help? It's my existing setup.
