Adding 2 Quad Breakers. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 04:08 PM   #1
Question
Adding 2 quad breakers.
Alright I'm trying to add an extra 40 amps to a room that will be used as a workshop.
The only problem is all the slots are filled up, is replacing the 2 30 amp breakers (2nd down from the top, left and right) with 2 quad 20/30 amp breakers a good idea for this panel I have?
They are currently being used for the A/C and water heater.
Thanks in advanced guys.
tattoojoe is offline   Reply With Quote
Old 10-10-2010, 04:12 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what is the panel manuf and model?
Old 10-10-2010, 04:20 PM   #3
I dont know, but I heard that you could use a simeiens, murray, or cuttler and hammer breaker in this.
How do I find out the manufactor and model of the panel anyways so I can be safer?
Old 10-10-2010, 06:13 PM   #4
nap
You talking to me?
nap's Avatar
it should be on the panel cover.
Old 10-10-2010, 07:04 PM   #5
Electrical Contractor
kbsparky's Avatar
You heard wrong!
That is a Square D "homeline" sub-panel, and it physically rejects most other brands of breakers except their own. One exception would be Cutler-Hammer's type CL breakers which are UL Classified for use in Homeline panels.
Depending on whether there are any additional bus-bar slots in that panel, you may or may not install any more tandems or quad breakers. You'll have to remove a couple of those full-size breakers to determine this.
Upload another photo with the top half breakers removed from the bus bars, and we should be able to see if the V slots are present or not.
-KB
All about quad breakers tns1 Electrical 1 08-30-2009 09:27 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
adding more breakers, few ?? mferguson0414 Electrical 12 01-17-2009 09:31 AM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
