Adding 2 Lights To A Switch That Powers A Light Already - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2009, 07:18 PM   #1
adding 2 lights to a switch that powers a light already
ok here is my problem i have a switch that powers the main light in my bathroom but i need to add two sconces(lights) that are controlled by the same switch that controls the main light. know that I can go straight from the main light in the ceiling to the other two lights but the thing is that I have to bust up the ceiling and drill through joists...I kind of want to avoid this if possible.
What I want to do is
run a line straight from the switch to the two sconces..and I need to know how to do this or if it is possible?
So basically the line would run like this
power-->switch-->Main light
`>light1->light2
I also have non grounded wiring with white and black and I'm going to use 14/2 for this. Is 14/2 ok to use with this?
Thanks,
Steve
Limit54 is offline   Reply With Quote
Old 11-06-2009, 07:45 PM   #2
Residential Contractor
2 quick questions before anyone can help you.
When you say non-grounded do you mean there is no bare wire in the romex??????
Also, check which circuit breaker feeds this bathroom. If it is a 15 amp, your 14-2 is ok. If it's a 20 amp, you need to ensure you have 12 gauge wire running to the bathroom and you need to use 12-2.
rselectric1 is offline   Reply With Quote
Old 11-06-2009, 08:09 PM   #3
joed's Avatar
Rewards Points: 11,518
In the switch box.
Connect all the whites together.
Connect the power black to one of the switch screws.
Connect the ohter two black together witha short black pigtail.
Connect the pigtail to the other switch screw.
At the lights
Connect all the black together and all the whites together.
Old 11-06-2009, 09:39 PM   #4
I have romex in the house. OK i will definitely check the breaker..I was unsure about the gage to use..thanks for clarifying that.
Ok Joed I'll hook that up.
Thanks so much.
i knew there was pigtails involved but i wasn't sure if it was correct.
Old 11-07-2009, 12:30 AM   #5
Good luck and be careful.
Old 11-07-2009, 12:56 AM   #6
What I want to do is run a line straight from the switch to the two sconces
If there are more than two wires in the switch box, yes. If there are only 2 wires in the switch box, no.
220/221 is offline   Reply With Quote
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-14-2009 12:09 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
