Old 08-02-2009, 04:19 PM   #1
Adding 15 amp light and switch on a 20 amp circuit
My question is about adding a 15 amp light and switch to a 20 amp circuit. I have a utility room I am remodling and have a 20 amp recepticle in place for my washer. I want to add a light and a switch to control the light in the room. I wired the room with 14/2 wiring and realized when I was finished that the recepticle is rated at 20 amps. Can I hook into this circuit with this wiring, switch, and light?
Jzack26 is offline   Reply With Quote
Old 08-02-2009, 05:02 PM   #2
DIYer
The washer circuit should be dedicated anyway, just run a new 15 amp circuit from the panel if you have room.
Gigs is offline   Reply With Quote
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
Adding a light to an existing 3 way circuit rlferdig Electrical 4 09-16-2008 03:47 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 01:43 AM
