| AllanJ |
12-16-2012 07:45 AM |
(not exactly on topic) In this case it would be overkill but is perfectly acceptable. While mixing of wire size within a circuit is usually discouraged, if you had a long run (like over 75 feet) and will be loading the circuit to near maximum, then it may be necessary to use thicker wire to avoid excessive voltage drop.
Unlike plumbing, it is not mandatory to run heavier wire for the entire length of a long run, but rather every additional foot of run for which the wire was heavier helps. The performance depends on exactly how much wire of each size was used and how many amperes are being drawn.
Sometimes 12 gauge wire for a long run extending an existing 14 gauge circuit is insufficient but 10 gauge wire for the extension will do the trick. That is, if it is too much trouble to run a new 12 gauge (15 amp) circuit.
