Adding 12 Gauge To 14 Gauge, Is It Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 01:56 AM   #1
adding 12 gauge to 14 gauge, is it ok?
I only have a few things in an existing 14 guage 15 amp circuit in my garage. Eventually I want to rewire it all so that it is 12 guage, 20 amp. But for now, I am adding a receptical to the circuit. Is it ok if I make run this with 12 guage while the rest of the circuit is 14?
farmerde is offline   Reply With Quote
Old 01-17-2010, 03:28 AM   #2
Provided that the circuit breaker is 15 amp, there should be no problem...
Aaron
exploreralpha is offline   Reply With Quote
Old 01-17-2010, 07:48 AM   #3
While it is not a good practice to mix wire sizes in a circuit, it can be done. Someone later on may see the #12 thinking they can upgrade the circuit to 20A, which they can't. As suggested above, the breaker MUST fit the smaller wire size.
Old 01-17-2010, 08:24 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Why not just leave what is there, there, and run the new stuff new???
"Re-wiring" an existing circuit is not what I would call a common practice.
Old 01-17-2010, 10:12 AM   #5
I agree with Pete, leave it & run a new #12 circuit
You can never have too many circuits or outlets in a garage
Old 01-17-2010, 10:34 AM   #6
Registered User
Termite's Avatar
That would be my biggest concern.
Old 01-17-2010, 01:55 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,030
If there is 14 Ga connected to the breaker why would anyone assume they could upgrade to 20 amp? If some one were to knowingly do this, they would not care about the code requirements.
Coastal South Carolina
Old 01-17-2010, 02:02 PM   #8
It's not a matter of knowing or caring about the code
If someone sees the yellow sheathing in the outlet box they realize its 12g wire
They know which breaker controls this...so they upgrade to a 20a breaker without verifying the wire in the panel or the rest of the circuit
Its just not best practice to mix wire
Old 01-17-2010, 02:10 PM   #9
" Euro " electrician
frenchelectrican's Avatar
The biggest issue due the OP did not mention attached or detached garage that will really ruin his day if not addressed correct.
Really for myself I will just run new 20 amp circuit and be done with it and not get the conductor size mixed up at all.
Merci,Marc
Old 01-17-2010, 03:41 PM   #10
People do a lot of things; some get the Darwin Award, some just get on the evening news, some get away with it.
If it's not prohibited by the NEC for technical or other reasons it still may be "bad practice".
I can see the OPs point. If house wiring came with a constantly updated "Read_Me_First.txt" file, it wouldn't be so bad.
Old 01-17-2010, 05:52 PM   #11
I agree with the other posters, it's far better to simply run a new 20 amp circuit than to simply replace part of the wiring with #12.
Aaron
Old 01-17-2010, 07:36 PM   #12
A "Handy Husband"
rjniles's Avatar
The OP has not responded to FrenchElectrician's issue as to whether this is an attached or detached garage. If attached a second circuit is fine, but a second circuit in a detached is precluded unless a MWBC (which is impossible given the OP's statements).
10 gauge vs 12 gauge wire for 30 amp line hsdude1992 Electrical 10 08-19-2015 02:43 PM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 02:16 PM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 08:50 PM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 01:55 PM
