Adding 1000/2000 W 240v Heater To 15 Amp 240v Circuit Running 1/2 HP Well Pump - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-04-2014, 05:31 AM   #31
Electrical Contractor
kbsparky's Avatar
Originally Posted by isaacjames View Post
Thank you everyone for your time, I did learn a few things!
One more question, can I run 14/3 wire to my heater or do I stay the same and run 12/3. I have lots of 14/3 hanging around.
You only need 14/2 on a 15 Amp protected circuit. But you can use 14/3 or 12/3 and ignore the white wire.
BUT if you changed the breaker to a 20 Amp, you must use #12 wire.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
micromind (01-04-2014)
Old 01-05-2014, 04:18 PM   #32
So all I need is the 2 hot leads? I havnt looked at the heater yet but I can ignore the one on the heater too if it has one.
isaacjames is offline   Reply With Quote
Old 01-05-2014, 08:16 PM   #33
Idiot Emeritus
Rewards Points: 1,492
And the ground.
In a case like this, black and red are usually used, white is not.
The heater will have two leads to connect to either the thermostat or power if it has a built-in stat.
micromind is offline   Reply With Quote
Old 01-06-2014, 08:31 AM   #34
Originally Posted by micromind View Post
And the ground.
Ok great, thanks!
sump pump on its own circuit mjklein67 Electrical 14 02-21-2012 06:51 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
Whirlpool and Sump Pump on same circuit? ksatc1 Electrical 5 06-23-2011 11:16 AM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
