-   -   Added new breaker, no garage lights now. (http://www.diychatroom.com/f18/added-new-breaker-no-garage-lights-now-152524/)
lum1nes 08-04-2012 04:39 AM
I installed a new 30A breaker into my 200A Square D breaker box. The only intent for this 30A breaker is to run a single outlet. So I got 10/2 NM-B Romex, outlet housing and outlet. Connected black (Hot) cable to outlet brass connecter, white (Neutral) to the silver connecter, and ground (copper) to the green connector on the outlet. I then ran the wiring to the breaker box. connected the hot wire to the 30A breaker, slotted the breaker. Connected both the ground and neutral wires to there respective rails. I turned off the master breaker before connecting anything to the breaker box. When I turned everything back on, the new breaker works great, tested along with running an appliance through it. Here is the issue: Now the garage lights do not work, along with the door bell and the porch light which are all on the same circuit. The outlets in the garage however do still work just fine. I retripped the breaker for the garage and still nothing, the only weird thing is the new breaker had a brownish goo like substance in the part that connects to the breaker box. I do not know if this is suppose to be there or if it is even conductive. My question really is How could me installing this breaker only affect these lights and nothing else? Specially the outlets on the same circuit? And what is this goo?
I will update with the exact model and pics of the setup and the goo substance when i get a chance.
Thank you in advance.
Jim Port 08-04-2012 06:40 AM
The brown was probably a grease.
You cannot run a general purpose circuit on a 30 amp breaker.
As for the lighting I don't know what your problem could be. Perhaps you loosened a wire in the panel.
rjniles 08-04-2012 09:03 AM
As Jim stated the max breaker size for a general purpose receptacle is 20 amps. You also need a GFCI receptacle for a garage (or a GFCI breaker). Tell us the planned use of this new receptacle.
stickboy1375 08-04-2012 09:30 AM
12 Attachment(s)
Originally Posted by lum1nes (Post 981073)
I installed a new 30A breaker into my 200A Square D breaker box. The only intent for this 30A breaker is to run a single outlet. .
That single receptacle has to be a minimum 30 amp rated.... As already stated by others. You didn't mention that part of the equation... as far as stuff not working, im guessing a loose connection or you inadvertently turned a breaker off.
electures 08-04-2012 10:01 AM
What is the 30A 120V receptacle for? As for the circuit not working, check and make sure a GFI receptacle did not trip somewhere.
lum1nes 08-04-2012 03:30 PM
The outlet is a 30a and is going to be used for an added 30a dryer downstairs. regardless of the intended use, I hadnt plugged anything into the outlet when the lights stopped working. I juss added the breaker and outlet and turned the breakers on.
Checked and retripped all the breakers, checked all the wiring in the breaker cabinet, nothing loose as i didnt touch anything within the box except for two screws on the rails.
I checked for a gci outlet and found none, as there is suppose to be one somewhere in the garage ill check again and hopefully that is what tripped.
stickboy1375 08-04-2012 03:37 PM
12 Attachment(s)
Well this certainly isn't good. You need to run 10-3 my friend...
electures 08-04-2012 03:58 PM
Or 8/3 AL SER.
lum1nes 08-04-2012 07:50 PM
Thanks for the responses all, for some reason i tripped the garage breaker again this morning and all is well. Of course this was after going through all the switches with a meter and testing all the connections.
I know it could be a few things but does anyone have any insight or a direction i should go for research as to how or why the lights would not work one night, and work just fine the next?
was thinking it could be a loose connection but i thought i tested and looked at everything.
