Added Circuit To Panel, Now How To Remove The Old Cable Clamp??????! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 10:12 AM   #1
Rewards Points: 91
added circuit to panel, now how to remove the old cable clamp??????!
I've added several circuits to my 200Amp panel to replace old circuits. I've added the new ones according to code but now I've got to remove the old wiring. They're held into the box with blue plastic cable clamps. There's a "key" that holds the wire in place in the clamp and two "tabs" that hold the clamp into the hole in the box. I've got to clean this mess up and it's proving more than a challenge just to remove the cable clamps. In both instances, the wires are on the back row of holes in the panel wall. This makes access somewhat problematic. What are the tricks to removing these !@#$%%^^&&**()_+}{":<>!!! clamps?
I (and my sparse hair) thank you for your assistance.
Allthunbs is offline   Reply With Quote
Old 12-04-2011, 11:39 AM   #2
My tricks for removing all things of that nature, not just electrical...
Channel locks have a curved top which can be used for leverage. Grip wire, then pry.
Cut the wire.
Vice Grips and pull!
Strip cover off cable, remove inside wires one at a time.
Cut wire on both sides and drill out center.
Come along attached to wire.
If all else fails, attach cable to wire and then to pickup truck! (Just kidding of course!)
Billy_Bob is offline   Reply With Quote
Old 12-04-2011, 02:23 PM   #3
Mad Scientist
Yep, I've always just crushed 'em with my lineman's pliers and ripped 'em out. It's probably possible to remove them gently and reuse them, but it's not worth it.
McSteve is offline   Reply With Quote
Old 12-04-2011, 07:03 PM   #4
Rewards Points: 91
Thank you gentlemen. Glad I wasn't going nuts and not seeing the obvious. Well, it looks like crush 'em & yank 'em ;-)
Allthunbs
Old 12-04-2011, 07:38 PM   #5
Licensed electrician
Rewards Points: 1,888
While I agree with the crush and destroy, you may be able to squeeze the tabs inside the panel with channel locks enough to pop it out of the panel.
Old 12-04-2011, 11:23 PM   #6
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Yeah, but crush and destroy is a LOT more fun!
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 12-05-2011, 05:27 AM   #7
Rewards Points: 91
Yeah, but that's LIVE 120V x 200 amps on the inside of that box. I'm not an electrician and I don't need a 120V "christening" to earn my spurs. Besides, I'm looking to clean up the box, not leave some fried parts of me behind ;-)
Old 12-05-2011, 05:47 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,..... Flip the main breaker OFF, 1st....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
pokey (12-05-2011)
Does sub panel feed cable need staples withing 8"? tpagel Electrical 3 05-30-2011 12:19 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Installing new circuit in panel - DIY? curls00 Electrical 18 03-13-2008 02:16 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
