Old 05-18-2008, 01:54 AM   #1
Added can lights, tripping GFI
Hey, I just added some can lights to my basement. On one switch there were two plain light fixtures that I traded out with two can lights--works fine. On the other side there was one light fixture that I traded out with 5 can lights--doesn't work fine. The first 3 can lights in the 'run' work, but the last two don't. The entire basement is on one 15 amp circuit and when I have all the can lights plugged in and turned on the GFI trips. So I unplugged the 5th light in the run and it still tripped, then I unplugged the 4th light in the run and now it works.
So two of my five on one switch trip the GFI. I don't have light bulbs in each of the can lights--could that be the problem?
Also, is there a certain length of run from switch to lights that I need to stay within? Between the 5 lights I am running about 42-45 feet. Can I change the wiring so that the first, second and third lights are attached and the first fourth and fifth are attached? Would that help?
I figured I would come on here and find out before wasting my time/money adding and removing wires...
tandyt is offline   Reply With Quote
Old 05-18-2008, 07:10 AM   #2
What do you mean by "plugged in?" GFCIs trip because you have a ground fault. Most likely, your neutral (white) is mistakenly touching earth ground.
LawnGuyLandSparky is offline   Reply With Quote
Old 05-18-2008, 08:26 AM   #3
So all that is happening is maybe one of the white wires is touching a ground wire inside the little box on the can light?
Plugged in as in hooked up... attached... Not plugged into the GFI.
Old 05-18-2008, 10:55 AM   #4
Yep, it was the neutral wire touching the ground in the 4th can light.
Thanks for the help.
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 11:02 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
