Add Undercabinet Lighting To Existing 3 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 09:47 AM   #1
Add undercabinet lighting to existing 3 way switch
Hello,
I'm a newbie to this blog but have been "lurking" for quite some time. Most of you on this site are professionals or at the least, from an electrical standpoint, more advanced than I am. So, I'll try to explain my situation but try to be gentle.
Recently I put this question on this site but probably didn't explain it well enough for it to make sense and never got an answer,so this is another effort. Sorry for the crude drawing but it's the best I've got.
What I'm trying to do is add undercabinet lighting to a kitchen and using LED lighting and hardwired. This should have its own switch so I want to add NM cable to an existing switch as shown in my drawing.
I've cut the sheetrock, drilled holes in the studs and ran the 14/2. Now I've tried every combination to attach the cable to switch number 2 in the dinning room but can't get power all of the time. I can get power when switch number one is on but not when it's off.
Can someone tell me the combination?
Thanks in advance,
Dale
Dale8 is offline   Reply With Quote
Old 10-21-2012, 12:23 PM   #2
joed's Avatar
Rewards Points: 12,002
Your drawing is too small. I can't read it.
Old 10-21-2012, 01:11 PM   #3
I'm trying to reformat the drawing and send another and better one but not having any luck.
Old 10-21-2012, 01:12 PM   #4
you can not tap in to a 3 way switch and power separate lights that are controlled by a different switch. if the power for the 3 way is in that box you can tap into that, but just connecting to wires on the 3 way will never work. in your drawing it looks like the power feeds to the box with 1 3-way and 1 single pole switch. where do you plan to put the new switch for the under cabinet lights? there is no hot wire in switch box 2 just wires for 3-way switches.
Old 10-21-2012, 01:26 PM   #5
DannyT.....I'm coming to the same conclusion that I just can't "splice" into any of the wires connected to the 3way switch because I've tried just about all combinations. I know my drawing is small and I can't seem to get it any better, but can you read it at all? Is their any way I can get a power source from either 3way in switch box 2 "before the 3 way outlet"? Does that make sense?
Dale
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Hardwire undercabinet lighting? theatretch85 Electrical 19 04-22-2009 02:29 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 01:43 AM
