Old 01-09-2006, 01:01 AM   #1
Add subpanel or upgrade main panel
I have a 100 amp 12 circuit main panel located in the garage, all circuits are full. I would like to able to add some circuits to the garage for woodworking tools, and perhaps a few more in the house. I see at least two options here: add a subpanel or replace the main panel (and probably the service to 200 amps). I would appreciate any ideas or opinions on this. This is not an urgent project so I want to consider all alternatives.
I should also note that I may also refinish the garage and could have the garage walls down to the studs, which may allow some additional flexibility.
thanks for any responses
dcoz is offline   Reply With Quote
Old 01-12-2006, 10:24 AM   #2
Well looks like you have 5 options.
1. Add sub panel
2. Replace main panel with a 200A Main $$$$$
3. See if your Panel will allow Tandem breakers, If so you can free up many spaces.
4.This depends on where you are. Ask local inspectors. You can put 2 hot wires on many single pole breakers. Make sure the breaker has 2 separate ports for the wires and add up your load to make sure you will not be tripping the breaker all of the time
5. Run a generator. Sorry had to add that one
BillK is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 08:13 PM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 03:21 PM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 12:28 PM
