Add A Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 04:46 PM   #1
New Home Owner
Send a message via MSN to cvolkers
Add a subpanel
We have been in our new home for about a year now. The basement is unfinished, and I am getting ready to start the framing of the basement. When the Electrician ran power to the utility room he wired in one outlet for the washer and then a switch for 4 lights. I think they are on the same circuit but I will check into that. The basement is about 1100 square feet. We are going to have a master bather, bedroom, Laundry room, family room and my office off to the side. I am curious if it would be better to run a single line for a subpanel in the basement or just run the extra circuits from the garage. The garage is already insulated and sheetrocked, no taped yet, everything in the basement is open. The lines going into the basement are Yellow, White and Orange. The orange is going to the water heater, the yellow is going to the outlet in the utility room for the washer, the white is going to the four lites that are already down there. There is also a 220 coiled up in the rafters in case future people want an electric stove. The Yellow, white and orange are all 110.
So there is my book. Looking for a little advise.
cvolkers is offline   Reply With Quote
Old 12-25-2008, 05:01 PM   #2
Rewards Points: 2,350
The "220" you speak of, what gauge cable is it, and how many conductors does it have? You may have your subfeed right there...
Old 12-25-2008, 05:27 PM   #3
joed's Avatar
Rewards Points: 12,912
The orage is probably 240 for the water heater.
What guage is the wrie put in for the stove? Is it copper or aluminum? That could be a good cadidate for a sub panel feed. Look on the cable for markings. It is likely 8/3 or 6/3. Those would be good for a 40 or 60 amp sub panel. Either should be enough for your needs.
Old 12-25-2008, 07:37 PM   #4
New Home Owner
The water heater is 110... The 220 wire for the stove is black and it says awg 10 or something on that order... how many wires I am not sure,,, the wire goes up inthe box behind the gas stove, but is not connected or live at this time...
Old 12-25-2008, 07:43 PM   #5
New Home Owner
I didn't see anything on the cable with 8/3 or 6/3. I did find awg 8 with awg 10 ground.
Old 12-25-2008, 08:02 PM   #6
If this cable has a black, red, white and bare ground, then you can use this to power a 40 A subpanel.
Old 12-25-2008, 09:21 PM   #7
Electrical Contractor
kbsparky's Avatar
...... The orange is going to the water heater..... The Yellow, white and orange are all 110....
My guess is that the orange wire for the water heater is a 240 Volt circuit.
That black line for a future range would be good for a 40 Amp subfeed which should be able to handle the rest of the stuff you are planning to put down there.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
