Add Socket To Light Switch That Controls Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 06:00 PM   #1
Add socket to light switch that controls fan
I have a ceiling fan that is controlled by a light switch. I tried to add a socket in between the switch and the fan to have both controlled by the switch, but now only the socket works when I flip the switch and and the fan no longer comes on.
It has 4 wires, 2white, 1red 1 black. I connected all 4 to the socket, but it seems to have terminated the power and no longer allows it to flow to the fan. Is there a way to keep both the socket and fan on the same 4 wires and manage them both from the light switch?
dhoggatt is offline   Reply With Quote
Old 02-16-2014, 07:11 PM   #2
joed's Avatar
Rewards Points: 12,924
One of the black or red wires is controlled by the switch. The other is always hot. Only connect one of them to the receptacle.
Old 02-16-2014, 07:26 PM   #3
Thanks for the quick response. Sorry, I am a noob. I have a back/white (hot) coming from the lead and red/white going into the line. I left the black/red in the socket and pigtailed the white; the fan came on with the switch, but the socket doesnt have any juice.
Thoughts?
Old 02-16-2014, 08:35 PM   #4
Rewards Points: 808
Whatever wires were connected to the fan should be the same wires connected to the new socket. Your color combinations don't make sense. Where is this new socket in relation to the switch, and in relation to the fan?
IslandGuy is offline   Reply With Quote
Old 02-16-2014, 08:39 PM   #5
the socket it in between the fan and the switch. I have red/white coming from the fan, and black/tan coming from the switch. Thought the tan was white in my earlier post, but looked closer and it is an off white.
When I connect all 4 wires to the socket, the socket works, just cant get the fan to come on.
Hope this helps explain where Im at.
Old 02-16-2014, 08:40 PM   #6
Rewards Points: 2,516
Sockets are not made to be used with electricity
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
dhoggatt (02-16-2014)
Old 02-16-2014, 09:42 PM   #7
Rewards Points: 808
Whay are there so many color combinations between the fan and the switch? I still don't get it, did you cut and interrupt the cable that goes from the fan to the switch? They should be black and white, or black white and red.
Old 02-16-2014, 09:45 PM   #8
To many uses of the word "it" to understand what the it is that you are referring to. Draw a diagram.
Had this diagram saved....In it the switch operates both the ceiling fan and the receptacles.
grounds are not shown for ease of drawing
Add socket to light switch that controls fan-lite-power-fan-light-combo-2-outlets.jpg
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 09:37 PM
light switch won't turn off light nredburn Electrical 4 11-20-2012 07:45 PM
Need to add a light near switch in 3-way setup.... prosper50 Electrical 5 03-19-2011 09:19 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
