Add An Outlet Where A Light Is Now - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 09:15 AM   #16
Rewards Points: 214
actually the red wire from the black cable goes directly to the light fixture like below
rosem637 is offline   Reply With Quote
Old 12-17-2012, 09:21 AM   #17
Rewards Points: 214
while I have some ears here, here is a shot looking down the rafter. Is it OK to have the loop of cable to way I have it. I left it there for when i want to add a few more outlets I will have the slack. The staples arent shown in the left but they are there.
add an outlet where a light is now-100_9692.jpg   add an outlet where a light is now-100_9693.jpg
Old 12-17-2012, 09:25 AM   #18
Rewards Points: 214
here are the two photos above somewhat cropped together
Old 12-17-2012, 11:12 AM   #19
Rewards Points: 322
I would tack so it is neater, but that is me.
I would also move the black cable so it is farther away from the roof in case the next roofer uses longer nails and hits it. I think you want it at least 1 1/2" away.
The "Light Box" should also have cable clamps, or just get a new plastic box.
tribe_fan is offline   Reply With Quote
Old 12-17-2012, 11:33 AM   #20
Rewards Points: 214
How to do it neater on the loop of white cable. Good call on moving black cable a little lower from roof deck.
Removing an end of the line outlet from the light switch lovetobuild Electrical 13 09-02-2012 01:07 PM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 09:08 AM
hard wire from light switch and outlet pennyeagle Electrical 0 08-27-2011 02:00 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
