Add An Outlet Where A Light Is Now - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 09:28 AM   #1
Rewards Points: 214
add an outlet where a light is now
In my attic I have a light but no outlet. Tired of running an extension cord up when I need power. The light is controlled by a switch which is not in the attic. At the light location there are 2 cables. see pic. I know the black cable goes to the switch. How would I add an outlet near here.
add an outlet where a light is now-bulb.jpg   add an outlet where a light is now-100_9688.jpg   add an outlet where a light is now-100_9689.jpg
rosem637 is offline   Reply With Quote
Old 12-16-2012, 09:39 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If you are sure the black cable goes to the switch. Connect a 2 wire cable to the white and black of the white cable. (Should be the 2 yellow wire nuts). Connect the bare grounds together. Install a single gang box for the new receptacle.
Coastal South Carolina
Old 12-16-2012, 09:57 AM   #3
Rewards Points: 214
Positive the black cable goes to the switch. Under the red wire nut there are both whites from each cable and the black to the light. Under one yellow wire nut are both blacks from each cable. Under the other wire nut are both grounds from each cable. I drew a diagram below. The gray lines are for white wires or cables.
Old 12-16-2012, 10:25 AM   #4
Rewards Points: 150
Dave632 is offline   Reply With Quote
Old 12-16-2012, 10:29 AM   #5
Rewards Points: 214
I would like the outlet in a seperate box. I want the outlet with power all the time. I dont want the outlet to only have power when the light is on(switch is flipped)
Old 12-16-2012, 10:30 AM   #6
Rewards Points: 214
Dave my response was to your comment but I see you deleted it.
Old 12-16-2012, 10:42 AM   #7
Licensed electrician
Rewards Points: 1,052
Just follow RJs advice and run the new cable to a new device box.
Old 12-16-2012, 10:46 AM   #8
A "Handy Husband"
rjniles's Avatar
Ignore my comment about the 2 yellow wire nuts based on your diagram. Use the yellow wire nut with the 2 blacks and the red wire nut with the 2 whites & the black.
While you are working on it replace that black pigtail under the red nut with a piece of white. That is a neutral and should be white.
Old 12-16-2012, 10:53 AM   #9
Rewards Points: 2,512
Follow RJ's wiring advice in the last post.
Then get a 4" square metal box, 4" raised duplex cover, a cable clamp and a receptacle and wire it up.
hammerlane is offline   Reply With Quote
Old 12-17-2012, 07:36 AM   #10
Rewards Points: 214
Thanks for the help. Everything works as I wanted.
Old 12-17-2012, 08:36 AM   #11
joed's Avatar
Rewards Points: 11,608
Now you can remove that adapter from the fixture socket and use the real receptacle.
Old 12-17-2012, 08:43 AM   #12
Rewards Points: 214
will do
Old 12-17-2012, 08:51 AM   #13
A "Handy Husband"
rjniles's Avatar
Originally Posted by rosem637 View Post
will do
I have to ask. I see the feed to the 4" square box with your new receptacle from the old light fixture box. But what is the cable leaving the 4" square going out of frame? Did you add another receptacle?
Old 12-17-2012, 09:07 AM   #14
Rewards Points: 150
I think the white cable is the feed, from right to left, then the black cable goes to the switch loop. See the diagram in post #3.
Old 12-17-2012, 09:10 AM   #15
Rewards Points: 214
The white cable comin in at the right of the square box with the outlet is the hot feed. I pigtailed in the square box to the outlet. The white cable leaving the square box on the left is taking power to the light fixture. The black cable leaving the light goes to the switch.
Removing an end of the line outlet from the light switch lovetobuild Electrical 13 09-02-2012 01:07 PM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 09:08 AM
hard wire from light switch and outlet pennyeagle Electrical 0 08-27-2011 02:00 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
